Username Post: 94 c1500 power steering pump        (Topic#280565)
jz512
Loc: Austin TX
Reg: 09-19-11
05-02-12 09:05 PM - Post#2221804
was just wondering if you can buy just the drive shaft or would be better of getting the whole pump.. the drive shaft on my pump wont tread..:( cant get the pulley pressed in.. i was going to rebuild the pump but now i need another one..or just the drive shaft..
navygunner08
navygunner08
Loc: New London, CT
Reg: 02-13-11
05-03-12 06:16 AM - Post#2221885
    In response to jz512
You should be able to find individual parts, but it may take some time searching. Ask your self this... Is the time and effort your going to spend on researching parts and rebuilding the pump worth it? Shop around and you can find pumps in the $40-60 range.
1994 K1500 Z-71
Execution time: 0.033 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:45 AM
