Username Post: Sugared Engine        (Topic#279887)
Allan In NE
Reg: 12-27-11
04-18-12 05:11 PM - Post#2216655
Anyone have a picture of a sugared engine? Preferably the inside? Need to prove a point to a 'non believer'.
Allan
Lifelong GM automatic transmission specialist
drifterdude
Reg: 09-04-08
04-18-12 06:10 PM - Post#2216685
    In response to Allan In NE
block with sugar in it
Better yet though as that was put in the filler to get in there I belive. Gas tank wise it does not do as much
You realy wana mess it up pour bleach in the tank.
It will get it hot enough to weld the block together just about and it does it quick. It washes the oil off the walls and makes it pure metal to metal and works its way into the crankcase and from there kills bearings. Much more effective.
92 K1500:350 bored 30 over,built 700r4,Comp extreme energy cam,double roller timing set,shaved heads,Rancho RS9000XL series shocks with wireless my ride system,35 inch Mickey Thompson Baja Claws,Relocated 4x4 switch to rocker on Dash.
Other mods..
100% CHEVY
100% CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
04-18-12 07:03 PM - Post#2216705
    In response to drifterdude
Myth Busters tried the sugar.Couldn't make it do anything.
They tried the bleach.Success!
Mike.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
04-18-12 07:32 PM - Post#2216715
    In response to 100% CHEVY
i saw that show.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
Lead sled
Lead sled
Loc: WALTON,NY.
Reg: 11-04-09
04-18-12 08:18 PM - Post#2216733
    In response to 62chevy427
Valve grinding compound works too.
51 BelAir 2drht 52 trim.Basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405,Saginaw 4spd/355 geared 55/6 Chevy rear.I just finished all the bodywork/paint myself.2,1st place trophies so far
55 Shaker
55 Shaker
Loc: north central IL.
Reg: 03-13-06
04-18-12 09:12 PM - Post#2216749
    In response to Lead sled
Ball bearings down the carb does wonders also.
drifterdude
Reg: 09-04-08
04-18-12 10:46 PM - Post#2216774
    In response to 55 Shaker
Sugar works just takes along time. If it sits it clumps and clogs and also helps to gum up the fuel system just takes alot of time.
Works better on fuel injection where it clogs injectors. Salt takes time but helps to rust things up even better on a vehicle that does not get day to day use as it has time to sit and rust up insides in the fuel system.
Other mods..
Allan In NE
Reg: 12-27-11
04-19-12 08:08 AM - Post#2216860
Oh for sure!
That stuff ought to be outlawed too!
Allan
Execution time: 0.075 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:10 AM
