Clarke57 (7)stefanPWagonsouth (2)74camaro (4)tri5ss (8)
Dadson 66project KeeferZJrMYFIRST64 (4) V8 supercars66JR
Don57 (9)50_Fastback62swagonRkoss71RICH57TRUCK (7)
63Biscuitjpfitpro
timmyg65Vaughn (13)RumblingV8 (2)
Monty56 (11)59fins (13)feffin (8)DonB51Chev (3)
MAC MAN
WagonCrazy (8)
Kevin Anderson (9)
Nailheadv8 (9)
Maui Doc
Exile® Battery Keeper™ 6/12 volt charger w/ LED battery monitor
Low priced Genuine GM Auto PartsHarbor Freight
Hellwig Products IncPerformance Rod & Custom
"Another reason of why this site and the people that participate in it are great. I have been in need of a good running engine for the fleetline and thanks to Patgizz I now have one. He was kind enough to give a nice 250 I6 motor. Thanks again Pat!!!"
Join the Community today
Username Post: Spark plug gap 45-60?        (Topic#276828)
Al-fourx
Loc: Las Cruces,New Mexico
Reg: 06-16-03
02-22-12 02:06 PM - Post#2193902
96 Sub 5.7 vortex 4wd 1/2 ton. The chiltons manual says 045 gap but autozone site says 060. What is right? The underhood label is gone.Have them set at 045 now but power seems a bet down.
84 K10 350/350 208TC 33" Tires 4" lift
02-22-12 02:19 PM - Post#2193905
    In response to Al-fourx
.045 would be where I would set them. You can run a wider gap but you're putting a strain on the rest of the ignition system to do so. Not a great idea.
Which plugs did you buy? Anything other than factory spec AC Delco 41-993 platinums, I would be reconsidering what I bought.
If power is down, time to check air filter, fuel pressure, possible exhaust restriction, etc. and general state of tune.
94 C2500LD / 94 C1500 / 06 300C SRT8
Execution time: 0.182 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:04 AM
