deek01BigDogSS (6)jk56chevy (11)WarrenL (2)Jens (10)
edad2000Custom_Deluxe_20VetteGyrl (2)JohnB (2)
speedygman (7)rickityfiftyMafo971Clifford Lao502drfleetline
Jud Leowish Non-synchronizedWGS53MobyVandurahereford
gary635g (6)
johnhem (10)
Greyimpala (5)
emil
axmaker (3)
socalarch (3)
usmile4 (8)
Exile® Battery Keeper™ 6/12 volt charger w/ LED battery monitor
Low priced Genuine GM Auto PartsEcklers AutoMotive
Hellwig Products IncPerformance Rod & Custom
""There is just to much knowledge here to not be here"."
Join the Community today
Username Post: Spark plug gap 45-60?        (Topic#276828)
Al-fourx
Loc: Las Cruces,New Mexico
Reg: 06-16-03
02-22-12 02:06 PM - Post#2193902
96 Sub 5.7 vortex 4wd 1/2 ton. The chiltons manual says 045 gap but autozone site says 060. What is right? The underhood label is gone.Have them set at 045 now but power seems a bet down.
84 K10 350/350 208TC 33" Tires 4" lift
02-22-12 02:19 PM - Post#2193905
    In response to Al-fourx
.045 would be where I would set them. You can run a wider gap but you're putting a strain on the rest of the ignition system to do so. Not a great idea.
Which plugs did you buy? Anything other than factory spec AC Delco 41-993 platinums, I would be reconsidering what I bought.
If power is down, time to check air filter, fuel pressure, possible exhaust restriction, etc. and general state of tune.
94 C2500LD / 97 Suburban LS1 / 06 300C SRT8
Execution time: 0.033 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:37 PM
