Carl1962 (2)briski1971 dfwwingnut CowboyTrukr (3)sz0k30 (6)
Suburbazine (2)Gunk(7)markl350 (6)roseyintxCutlass442 (10)Rager
Chevyfan60 (10)JohnE (12)cnbell (11)Todd M (11)savina64
LRH (3)61ohboy66conv55_FEVER george88gta (10)BillOrton39
68 Bel-AirNitroholic (10)
warpwr (8)Lynn63 (5)
Jim.Biron (7)
1956chevy (2)
BMF-1955
Hellwig Products Inc Performance Rod & Custom
Exile® Battery Keeper™ 6/12 volt charger w/ LED battery monitor
""There is just to much knowledge here to not be here"."
WIN / WIN
Use this to search for parts on Ebay
A portion of your purchase will come back to the site.
Username Post: Spark plug gap 45-60?        (Topic#276828)
Al-fourx
Loc: Las Cruces,New Mexico
Reg: 06-16-03
02-22-12 02:06 PM - Post#2193902
96 Sub 5.7 vortex 4wd 1/2 ton. The chiltons manual says 045 gap but autozone site says 060. What is right? The underhood label is gone.Have them set at 045 now but power seems a bet down.
84 K10 350/350 208TC 33" Tires 4" lift
02-22-12 02:19 PM - Post#2193905
    In response to Al-fourx
.045 would be where I would set them. You can run a wider gap but you're putting a strain on the rest of the ignition system to do so. Not a great idea.
Which plugs did you buy? Anything other than factory spec AC Delco 41-993 platinums, I would be reconsidering what I bought.
If power is down, time to check air filter, fuel pressure, possible exhaust restriction, etc. and general state of tune.
94 C2500LD / 94 C1500 / 06 300C SRT8
Execution time: 0.148 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:31 PM
