mechalemark1963Chevyfan60 (12)Brogie (6) carolinakid (4)steve65NY1960 (12) asbicca (5)NY1960 (12)Mike Lemons (6)Bcrem warpwr (9)50sChevys (13)
racerdan61
savina64 (2)
Ciadella InteriorsAmerican Auto Wire Ecklers AutoMotive
Join our CommunityClassic Industries
Hellwig Products IncPerformance Rod & Custom
LMC Truck Join the Community today Join Us Now
Username Post: Spark plug gap 45-60?        (Topic#276828)
Al-fourx
Loc: Las Cruces,New Mexico
Reg: 06-16-03
02-22-12 02:06 PM - Post#2193902
96 Sub 5.7 vortex 4wd 1/2 ton. The chiltons manual says 045 gap but autozone site says 060. What is right? The underhood label is gone.Have them set at 045 now but power seems a bet down.
84 K10 350/350 208TC 33" Tires 4" lift
02-22-12 02:19 PM - Post#2193905
    In response to Al-fourx
.045 would be where I would set them. You can run a wider gap but you're putting a strain on the rest of the ignition system to do so. Not a great idea.
Which plugs did you buy? Anything other than factory spec AC Delco 41-993 platinums, I would be reconsidering what I bought.
If power is down, time to check air filter, fuel pressure, possible exhaust restriction, etc. and general state of tune.
94 C2500LD / 97 Suburban LS1 / 06 300C SRT8 / 06 Magnum SRT8
Execution time: 0.096 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:38 AM
