Username Post: fuel line fitting for Holley 0-1850        (Topic#319007)
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
12-14-14 06:23 AM - Post#2506151
I'm considering using a simple and inexpensive Holley 0-1850C for the mild 355 I'm assembling for my 82 pickup. I'd like to use a 5/16" steel fuel line from fuel pump to carb. Is there a swivel inverted flare fitting available to replace the hose nipple that comes with the carb? I can't find one anywhere.
BB Biscuit
BB Biscuit
Loc: Washington
Reg: 03-30-02
12-15-14 12:15 PM - Post#2506507
    In response to MikeB
I did some searching and came up empty. you can get AN to hard line fittings. You could go with AN out of the carb then to hard line. But then again the expensive part is the fittings.
AN and braided line pump to carb? Looks cool.
I'll keep searching. I would think somebody makes what you are looking for.
65 BB biscayne,73 RS Z28,04 2500 ex cab 4X4,67 Nova,77 chev shorty van
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
12-15-14 04:18 PM - Post#2506583
    In response to BB Biscuit
Yeah, I found a -6 AN fitting that will work. Already have some hose and hose ends, and even a fuel pump flare fitting, so may go that route.
On another note, do you have a link to pictures of your truck? From what I can see in your avatar, I like the stance. What did you do to front and rear suspension?
Edited by MikeB on 12-15-14 04:20 PM. Reason for edit: No reason given.
BB Biscuit
BB Biscuit
Loc: Washington
Reg: 03-30-02
12-15-14 06:00 PM - Post#2506611
I've been a little lazy on the picture taking on this one. I'll work on getting some.
It has 2" drop springs with 2.5" drop spindles in the front.
The rear I did a low buck flip.I bought spring perches from jegs and welded them on. Then I made rear shock mount extenders. This is the second one of done that way.
The last one was an 84 step side. I got a lot of compliments on that one to the point that somebody else decided he needed to own it. So I sold it to him.
BB Biscuit
BB Biscuit
Loc: Washington
Reg: 03-30-02
12-16-14 08:07 AM - Post#2506761
I was looking at my truck yesterday in the parking lot at work and noticed it sits lower than in the picture I posted.
The Pictures of both trucks were taken right after I set them back on the ground after doing the drop.
Backed straight out of the shop 50' and stopped.
Now that I have driven it around it has settled more
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
12-16-14 08:46 AM - Post#2506768
I was thinking around 2" front and 2" rear on my truck. Up front I will probably use spindles to preserve ride. However, I need to get familiar with ways to drop the rear. Looks like the extended shackle method will do it for me, but haven't seen any instructions, pictures, etc. to see what's involved.
octanejunkie
octanejunkie
Loc: Los Angeles area
Reg: 11-12-09
01-10-15 06:35 PM - Post#2513687
Mono leaf springs w reverse eyes will drop better than longer shackles without changing the spring rate
'59 Chevy 3100 Stepside
0.030-over 350, mild (214/224 @ .050) 112 LC cam,
vortec heads, air-gap, 600cfm carter, Holley Avenger EFI, 2-1/2" rams horns,
Bowtie Overdrives 700R4 w 2200rpm stall, 3.42 posi rear on top of 31.5" BFGs
Execution time: 0.316 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:44 PM
