sidewayz
Reg: 06-27-12
06-27-12 07:24 PM - Post#2242104
hello eveyone im new to the fourm this is my first post so dont be to hard on me please. but im build a chevy motor for a dirt track super stock and im going to use stock heads this year and im trying to find the best head to use here are my rules
G.M. may use any production head with a maximum intake valve diameter of 1.94;
maximum exhaust valve diameter will be 1.60. No angle-plug heads allowed on Chevrolet.
No "bowtie" or Vortex heads allowed. Vortex cast no. 10239906. Other
casting numbers not allowed are 14011083 and 14096217, 10239906, 1012532,
10208890 and 12554290
models916
Loc: Addison, IL
Reg: 05-28-10
06-28-12 08:31 AM - Post#2242256
In response to sidewayz
Grumpy Jenkins book on page 69 lists the 461 head as the best casting ever for the 1.94 valve.
sidewayz
Reg: 06-27-12
06-29-12 03:37 AM - Post#2242496
In response to models916
i thought thoes dont have acc holes would there be a way to run a power steering pump?
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
06-29-12 05:01 AM - Post#2242518
http://billshotrodcompany .com/673/715.html
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics |
models916
Loc: Addison, IL
Reg: 05-28-10
06-29-12 05:21 AM - Post#2242527
Short water pump and early style pump mount.
sidewayz
Reg: 06-27-12
06-29-12 06:20 AM - Post#2242552
so will i be able to run a pump like this one with that set up?
http://compare.ebay.com/like/290379513342?var =lv&a...
mokicruz
Reg: 12-11-04
06-29-12 06:13 PM - Post#2242779
I used to bolt on the brackets and used them as a guild to drill and 3/8 and tap the head for a 3/8 bolt. I sealed it with RTV and a 3/8 O ring on the bolt when I put washers as spacers then tightened it down to 20 ft lbs of torque.
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
06-30-12 05:21 PM - Post#2243079
Check Alan Grve components, they have a PS bracket that does not need bolt holes in the head.
'57 210, Blown 327 cid, Holley HP TBI, 700R4, A/C
'08 Corvette Jetstream Blue coupe.
'96 Replica of a 1950's Teardrop Trailer. |
