Username Post: New high torgue starter?        (Topic#280948)
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
05-10-12 06:14 PM - Post#2224606
Okay, got one of the new mini starters DB Electric. They didn't send a measuring device to set the starter. So what is the measurement? From the shaft of the starter bendix to the teeth on the flexplate?
I am going to pull the motor out of my nova and put a new flexplate on along with the starter? Some help would be great here, so I know when I have the motor out.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2005 Yamaha Vstar 1100 midnight custom
05-10-12 08:54 PM - Post#2224669
    In response to busterrm
it should be like the thickness of a credit card. that is with the starter engaged into the flywheel. cut up one of your wifes credit cards and stick a strip in there between the teeth.
70 L camino 350 all forged,174 baby blower, g-force 5 spd, road rage suspension. Pray first before all else fails.
rumrumm
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
05-11-12 08:00 AM - Post#2224794
    In response to bobb
  • bobb Said:
Cut up one of your wifes credit cards and stick a strip in there between the teeth.
Ha! I like that suggestion! You can also use a large (1 1/2 ") paper clip as a gauge.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, Sanderson. Dyno #'s: 450 hp @ 5700, 468 ft. lbs. torque @ 4300.
http://photo.net/photos/Lynn%20Johanso n
busterrm
busterrm
Reg: 08-31-10
05-11-12 03:58 PM - Post#2224932
    In response to rumrumm
okay is there a way to engage the bendix without spinning the starter? The big terminal is to spin the motor right. So in theory if you use just the small terminals just the bendix should engage right?
I am not much on electrical stuff and I just want to screw it up.
==== BOB ====
1976 Chevy Nova
Edited by busterrm on 05-11-12 03:59 PM. Reason for edit: No reason given.
phat rat
Loc: muskegon mi
Reg: 09-02-09
05-11-12 07:04 PM - Post#2224985
You don't need to engage it electrically. You can do it manually
busterrm
busterrm
Reg: 08-31-10
05-17-12 09:24 PM - Post#2227044
Okay,
I don't have a wife! Thank God! I am not sure I want one either. Anyway, my buddy David raided his wife's purse, really pissed her off, and cut up a expired credit card. I unbolted the converter,tranny and backed it off. I bolted the new flexplate and starter on then I shimmed it and got a sliver of that credit card in. Bolted the converter and tranny back up getting it back together in one afternoon. The thing is a like a rambo of starters.
==== BOB ====
1976 Chevy Nova
Execution time: 0.098 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:04 AM
