Dukeofdull
Loc: Cow Hampshire
Reg: 12-17-04
12-30-11 06:03 AM - Post#2173818
What's causing the needle on my speedo to wave back and forth?
YeniPenny
Loc: Biloxi, Ms
Reg: 11-26-01
12-30-11 09:43 AM - Post#2173871
In response to Dukeofdull
Normally, but not always, the cable is dry or needs replacing.
Dukeofdull
Loc: Cow Hampshire
Reg: 12-17-04
12-30-11 12:11 PM - Post#2173924
In response to YeniPenny
Yeni, Lubricate with light oil (?) Graphite maybe (?) or something more specific. Thanx, johnny
beejay
Loc: Pflugerville, Texas
Reg: 06-01-04
12-30-11 04:18 PM - Post#2173990
What year?? You lube different years in different ways. There is a speedo lube called "Speedometer Lubrication Liquid Graphite" that is the best to use. Dry graphite will not work, as it will not go down the cable. If you have a one-piece cable, lube from the speedo head. Mine is a two parter. I lube from the speedo head (NOT very much), and in the engine compartment by taking the connector apart. I've got just the opposite, or different problem. Tach fluctuates until it get warm enough. Yeah, needs lube also on the shaft. Oh, on the speedo, you might also want to take the speedo out and lube it also. AND, add some grease on the odometer gears.
Bruce
http://www.picturetrail.com/beejay3/" |
Dukeofdull
Loc: Cow Hampshire
Reg: 12-17-04
01-02-12 04:58 AM - Post#2174817
In response to beejay
Bruce, I have a 1981 El Camino... Thanx
YeniPenny
Loc: Biloxi, Ms
Reg: 11-26-01
01-02-12 08:38 AM - Post#2174850
The cable should be completely removed from the sheath in order to lube properly. A graphite based lube is best.
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-02-12 06:39 PM - Post#2175087
Clean it with varsol/paint thinner to get all the old stuff off the cable inside. I soaked my cable in a gear oil and wiped off all the excess before putting it back inside the sheath. I haven't used graphite myself.
59 El Camino, 62 Bel Air SC, 62 Bel Air SC(sold in Finland is 2011), 63 SWC Vette (sold)
Member #2194 |
beejay
Reg: 06-01-04
01-06-12 01:53 PM - Post#2176440
In response to DonSSDD
"I haven't used graphite myself."
lol Well, neither have I. BUT, I've used it, liquid type, on speedo cables many times.
Bruce
