Senior Chevytalk Moderator
06-15-12 05:50 AM - Post#2237348
Finally getting back to the A/C on my truck. I dropped off the compressor for new seals. I did install the R134 condensor last year. We'll do a good flush and vacuum. I can't wait to drive it more. It may be a daily driver while I do major a-arm bushing on my Jimmy. Right now, I'm driving around with a bypass pulley. I'll snap pictures.
'96 GMC Jimmy LS |
Chevytalk Moderator & "3rd Year" Gold Supporting Member
Loc: Montgomery, AL
Reg: 01-15-02
06-15-12 06:24 AM - Post#2237355
I bought the GM serpentine setup w/AC for mine, $750 at Jegs.
1979 2wd K5 Blazer, 350/TH350
1985 4x4 M1009 K5 Blazer, 6.2/TH400 |
06-15-12 08:29 AM - Post#2237401
In response to John
I can't remember which way the orfice tube faces! I think short in first. Should be ready in a few hours
'96 GMC Jimmy LS |
bowtieollie
Reg: 12-06-99
06-15-12 05:14 PM - Post#2237586
In response to John
OUCH! $750 for a belt kit???
What's the ROI on that accessory??????
Bowtieollie
Chevytalk.com Moderator |
bowtieollie
Reg: 12-06-99
06-15-12 05:15 PM - Post#2237587
Yoooo G,
Look at the orifice tube.... the "tangs" face the fitting - so the extractor tool can engage.
Bowtieollie
Loc: Montgomery, AL
Reg: 01-15-02
06-15-12 06:54 PM - Post#2237623
In response to bowtieollie
I didn't think it was that bad. Here it is.
06-17-12 04:46 AM - Post#2238137
In response to John
Orfice tube goes in short side in. There is an arrow pointing flow direction.
With city driving, <45 MPH, it's blowing down to 60 degrees!! Not bad for days with temperatures between 95 and 100!! I bet on the highway, it will get down even more. I do notice a slight cooling delay. Mostly when the electrical fans are off cause the engine is cold. Once the engine reaches operating temps, the fans run at stops, slow speed, or idle. Fans have a switch to turn on at 205 and off at 190. Now, I have to find a way to seal the gap between the condensor and radiator. Better airflow through the condensor will increase cooling efficiency.
Now if only fuel prices would drop about $1 so I could drive it every day.
'96 GMC Jimmy LS |
Loc: Montgomery, AL
Reg: 01-15-02
06-17-12 10:09 AM - Post#2238242
Congrats on the cold air. I hope to enjoy some in mine soon. G, did you do a write-up on your fans when you put them in?
06-17-12 10:51 AM - Post#2238259
In response to John
I did, but Yahoo ditched Geocities and all my info. I do have pictures of the LS1 Camaro fan install. Basically, I just wired them into the harness from the previous dual fan setup. I need a complete new site to load up all I have available. Including the 88-91 front end conversion. I only took pictures of the ram air setup.
I'm going to run the LS1 setup like this for a while. I have Mark VIII fan sitting in the garage. If temps over 100 become a cooling problem, I may install it. I can run low speed with the A/C compressor. High speed with the head temperature probe.
I will need a fan shroud to complete an install. Here are instructions I would follow: http://www.off-road.com/trucks-4x4/project/pr oject...
'96 GMC Jimmy LS |
Loc: Montgomery, AL
Reg: 01-15-02
06-17-12 06:17 PM - Post#2238434
Thanks G. I haven't decided yet on the e-fans, I might find out I have to run them. Not that I'd mind. I am looking forward to AC tho, I haven't had a square with air since 1990.
