Username Post: Lund lighted moon visor        (Topic#280939)
DD74Chevy
DD74Chevy
Loc: Idaho
Reg: 12-10-11
05-10-12 03:00 PM - Post#2224547
I just picked up a Lund lighted moonvisor for 10 bucks at a yard sale. Good condition. My question is there are 2 wires positive and ground how do i hook them up to my running lights without them blinking when i turn the turn signal on? Thanks in advance
My TOYS
74 Chevy 1/2 ton 4x4. Crate 350.Edelbrock intake,cam and carb.
93 K5 Blazer 350tbi,700r4,flowmaster 40 series
98 Chevy 2500 6.5 Turbo Diesel vin F 4x4 Ext cab long box
00 Pontiac Grand am GT 3.4l
technitom
technitom
Loc: Near Cincinnati, OH
Reg: 12-01-11
05-10-12 05:07 PM - Post#2224587
    In response to DD74Chevy
you dont want to wire into the turn signal line
you want to wire into the running lights (hot) thru headlight switch...
the other line goes to ground
Words are a lot like toothpaste... Once its out of the tube,
there's no getting it back in...
technitom
technitom
Reg: 12-01-11
05-10-12 05:12 PM - Post#2224588
    In response to technitom
brake and turn is on one line.
running lights on another...
pull headlight switch 1/2 way out and use a test light to find the hot line going out to running lights from the headlight switch...
one of you visor wires taps to the mentioned hot line, the other goes to chassis ground...
Edited by technitom on 05-10-12 05:12 PM. Reason for edit: No reason given.
DD74Chevy
DD74Chevy
Loc: Idaho
Reg: 12-10-11
05-10-12 08:58 PM - Post#2224670
Ok i will try that this weekend and hook them up. I put my batt charger on the wires to see if the lights come on and they all come on so im good there. Will hook them up to the switch this weekend. If i can get my headlight switch out that is lol. Last time i tried and got frustrated and said forget it. But will try again
My TOYS
technitom
technitom
Reg: 12-01-11
05-11-12 03:09 PM - Post#2224916
reach under dash, there is a spring loaded button you have to push in as you pull the headlight switch out>>> all the way... the switch pull comes all the way out of the switch...
then remove the keeper nut and the switch assembly should fall backwards under the dash.
if the wiring is long enough, it will dangle under the dash.
put the switch rod back in. work the switch in and out to make sure it works, pull switch 1/2 way out to turn on running lights.
find the hot feed to running to the running lights
DD74Chevy
DD74Chevy
Loc: Idaho
Reg: 12-10-11
05-12-12 08:46 AM - Post#2225126
Thanks i will try this today and see. Thanks again!!
My TOYS
DD74Chevy
DD74Chevy
Loc: Idaho
Reg: 12-10-11
05-13-12 07:28 AM - Post#2225400
Works perfectly. Was a little challenge to get the switch off. Previous owner put a birds nest of wires under there. Going to have to fix that real soon. But the lights are working. Thanks
My TOYS
free_bird49221
free_bird49221
Loc: Adrian, MI
Reg: 04-29-12
05-13-12 08:07 AM - Post#2225410
im jealous you found it so cheap. looks good though. makes for a nice addition to a already good looking ride
Ande
81 GMC c2500
06 Chevy Malibu
80 Olds cutlass
DD74Chevy
DD74Chevy
Loc: Idaho
Reg: 12-10-11
05-13-12 08:35 AM - Post#2225425
    In response to free_bird49221
Thanks man i appreciate it. Yeah i was surprised on how cheap the lady was asking for it. When she said uhh how does 10 dollars sound i said sold!! It does look good i like the way it turned out. Just needed a little paint and she looks awesome.
My TOYS
free_bird49221
free_bird49221
Loc: Adrian, MI
Reg: 04-29-12
05-13-12 09:55 AM - Post#2225448
Rattle cans are cheap and easy if need be. Hard parts done. Good job
Ande
81 GMC c2500
06 Chevy Malibu
80 Olds cutlass
Senior Chevytalk Moderator
05-13-12 12:08 PM - Post#2225475
Make them flash like "Close Encounters of the Third Kind"!!!
'96 GMC Jimmy LS
DD74Chevy
DD74Chevy
Loc: Idaho
Reg: 12-10-11
05-13-12 03:27 PM - Post#2225526
Oh yeah they are cheap and very easy just have to spray evenly so you dont get heavy spots with runs. Thanks man.
My TOYS
DD74Chevy
DD74Chevy
Loc: Idaho
Reg: 12-10-11
05-13-12 03:30 PM - Post#2225528
Lol that would be cool to do that and block of the lower marker lights and park on a hill in the mountains near town and just have them flashing at night and freak people out lol. Or make it stream flash like knight ryder
My TOYS
technitom
technitom
Reg: 12-01-11
05-14-12 12:31 PM - Post#2225847
Looks good! I take it my "destructions" worked out ok for you?
DD74Chevy
DD74Chevy
Loc: Idaho
Reg: 12-10-11
05-14-12 03:11 PM - Post#2225878
Oh yea it worked out perfectly!! Thanks again man for all your help! Much appreciated!!
My TOYS
Execution time: 0.248 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:20 AM
