tarps (7)
Username Post: Frame dimensions?        (Topic#280858)
cloudmaster
cloudmaster
Loc: Arrowsmith, IL
Reg: 01-30-02
05-08-12 11:09 PM - Post#2224038
Can anyone get me the correct dimensions between the framerails over the front crossmember? I'm having a hard time getting some new motor mount inserts to fit in my '85 3/4 ton 2WD (w/ 454) stock clamshells, and I'm mildly suspicious that some over-exuberant driving maneuvers (which, at times, "may" have resulted in all four wheels several feet off of the ground) executed as a younger, less married man may have resulted in a mildly taco'd frame.
The increased compliance of the stock rubber v/s the less-forgiving poly seems, to my mind, to be a plausible explanation. Or there's something weird about my truck. But if someone has a truck which hasn't ever left black marks in all four wheel wells (IMHO: particularly impressive with a heavy-haul option'd 3/4 ton suspension and an empty bed), I'd appreciate comparing some dimensions...
Thanks. And no, this was before everyone had video cameras in their phones, so I don't have pictures. :/
'71 Malibu: 350/200-4R/3.73 Eaton posi
'75 Elky: 350HO/TH350/3.42 peg leg
'85 C20: 454/TH400/3.73 locker
'95 Caprice Wagon: LT1/4L60E/3.42 posi
'95 BMW 740i: untouched, but a V8
'04 Grand Marquis: 2V4.6/3" pipes/SCT flash
cloudmaster
cloudmaster
Loc: Arrowsmith, IL
Reg: 01-30-02
05-09-12 07:54 PM - Post#2224341
    In response to cloudmaster
I just got a 3 foot length of 7/16 all-thread (and 4 nuts 'n 4 washers), cut that in half, and bolted each half into the engine mounts on the engine, and measured between them. Then I stuck the same all-thread into the frame mounts, and put my ten ton porta power (from Harbor Freight - currently on sale for $179; actually a recommended purchase) between the frame rails, and pushed the top edge of the frame in front of and behind the frame brackets until the measurement was about 1/8" wider than it needed to be. Then when it sprung back, it was very nearly perfect. So, exact measurements of the frame are less important to me now.
Execution time: 0.022 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:41 PM
