Username Post: leak!!!        (Topic#280420)
marsmetz
Reg: 11-14-11
04-30-12 09:09 AM - Post#2220648
Hi i just replace my glove box with a cardboard one and after the rain the entire box was filled with water! Any suggestions
bobschevytrucks.com
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
04-30-12 04:09 PM - Post#2220795
    In response to marsmetz
I put my guess on the windshield gasket probably at the right hand top corner.
http://photobucket.com/C10Pictures
JimKshortstep4x4
Chevytalk Moderator & "9th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
04-30-12 04:32 PM - Post#2220806
As mentioned the windshield seal is a likely problem. Make sure the roof caulk is good also, as it does harden and break up over time.
Member 65-66 Full Size Chevrolet Club
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
71 Short bed stepside 4x4, 350/350
Current project, 72 GMC Shortbed, stepside, 427
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
05-01-12 08:14 AM - Post#2221083
I bet it is one of the two above mentioned sources of your problem. If not, you might check under the outter w/s wiper cowling for leafs blocking the cowl drain??
I'd also check the antenna cable seal there...
bobschevytrucks.com
Execution time: 0.031 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:04 PM
