snowman66
Reg: 03-30-12
03-30-12 07:31 AM - Post#2209156
could any one tell me what the wheel alignment specs are, foa my 1966 chevy c10. Short box,2wheel drive. Thank you
persh
Loc: Tucson, Arizona
Reg: 07-19-00
03-30-12 03:07 PM - Post#2209284
In response to snowman66
Camber: +0°15'
Caster: +2°27'
Toe-In: 3/16"
Big fenders
Loc: Tucson Arizona
Reg: 04-30-04
03-31-12 07:43 PM - Post#2209712
In response to persh
persh...are those specs the same for manual steering and also power steering? I thought I heard that one was different. Maybe I'm wrong...
Bob
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
04-01-12 01:02 PM - Post#2209937
In response to Big fenders
They are the same whether power or manual.
As I said recently, manual gears used less caster to make the truck easier to steer at slow speeds (like when parallel parking).
The power gear can handle more caster, but since it was the first couple of years for power steering ON TRUCKS - the factory didn't take advantage of the greater force available for the power steering gear. If you have factory (or aftermarket) power steering, you can add a couple of degrees of caster to the stock setting to improve the return-to-center feel on the steering.
