Username Post: striped the harmonic bolt 396        (Topic#279208)
gbrown65
Reg: 04-05-12
04-05-12 07:40 AM - Post#2211604
what is the bolt size that holds the hharmonic on a 68 396 i think i striped it out
Edited by gbrown65 on 04-05-12 07:50 AM. Reason for edit: No reason given.
capricesport66
capricesport66
Loc: Lafayette, Louisiana
Reg: 11-02-03
04-05-12 07:51 AM - Post#2211607
    In response to gbrown65
1/2" bolt.
How did you strip it, trying to put a new balancer on?
Gerald
Lafayette, La.
http://www.flickr.com/photos/95648804@N08/
'66 Chevy Caprice 2DR HDTP 496/4L80e/3.73, 20's, Console, Buckets
'06 Chevy 2500HD 4x4 LBZ Duramax/Allison
'08 Toyota Highlander "Hybrid"
'99 VW Jetta TDI
gbrown65
Reg: 04-05-12
04-05-12 07:53 AM - Post#2211611
    In response to capricesport66
yes when i did must of bottom the bolt out with impact think the treads are messed up
capricesport66
capricesport66
Reg: 11-02-03
04-05-12 07:57 AM - Post#2211612
That's terrible news if you did strip it. Means lots of work in a very tight spot or pulling the crank.
One thing that usually needs to be done on a new harmonic balancer is to have it honed a little for the clearance problem. If you do manage to get a new balancer on, you can almost bet that you'll probably never get it off without a serious fight.
Unless you have a different balancer bolt of some sort, you shouldn't have bottomed the bolt out.
Gerald
Lafayette, La.
'99 VW Jetta TDI
gbrown65
Reg: 04-05-12
04-05-12 08:00 AM - Post#2211613
you think i can retap and put new bolt in and your rite it mite not ever come off agian maby i can run it without
capricesport66
capricesport66
Reg: 11-02-03
04-05-12 08:10 AM - Post#2211619
You would do better off calling around to a local machine/engine shop about the retap. It can be done, but there are other questions to ask like about the integrity of the crank itself if more metal is removed. Is the crank iron or steel.
Running an engine without a bolt would be risky as you never know if it will or will not come off. It's a chance I wouldn't take. The key will prevent it from spinning, but what about walk? What if that crank key breaks, then timing would go crazy and possibly cause engine damage.
Gerald
Lafayette, La.
'99 VW Jetta TDI
ed72073
ed72073
Loc: Chicago
Reg: 12-08-10
04-05-12 08:19 AM - Post#2211621
If you retap it you will need a bigger size bolt or maybe a coarse thread bolt (1/2 X 13). If you try and use the original bolt it will not hold because you pulled the threads already. It is pretty easy to drill new hole and tap new threads once you can get a drill in there. You will feel the drill bit bottom out but I would mark the bit so you also know when to stop. To tap it just go slow and take your time and use oil, if you brake the tap have fun.
Allan In NE
Reg: 12-27-11
04-05-12 08:31 AM - Post#2211625
Retap the original hole the same size and get a new bolt.
Forget the silly impact. The balancer goes on with a 2 lb. hammer. Listen for it to bottom on the thrust bearing; you can tell when it's home.
Tighten with a ratchet this time and don't get carried away because those threads are gonna be weak.
Allan
Lifelong GM automatic transmission specialist
capricesport66
capricesport66
Reg: 11-02-03
04-05-12 08:53 AM - Post#2211632
    In response to Allan In NE
Allan,
Sometimes that hammer won't work. My last balancer wasn't going to get on no matter what. It would stop about halfway. With that said, the different manufacturers are clearanced in different ways. My last job was putting a powerbond sfi rated balancer on a SCAT forged crank. I had to have it honed.
Get an OD/ID caliper and check the measurements. Balancer companies purposely make the bore undersized. My balancer was .005 undersized and would not move on. I had it honed to .002 and it worked like a charm, still tight though.
Gerald
Lafayette, La.
'99 VW Jetta TDI
capricesport66
capricesport66
Reg: 11-02-03
04-05-12 08:55 AM - Post#2211633
gbrown,
What balancer did you buy? There should be instructions in the box that will tell you about the bore size. With this information, you'll need to measure your crank to see what size it is.
Gerald
Lafayette, La.
'99 VW Jetta TDI
gbrown65
Reg: 04-05-12
04-05-12 09:01 AM - Post#2211640
any idea what size tap and bolt
gbrown65
Reg: 04-05-12
04-05-12 09:06 AM - Post#2211642
thanks for the info think i got it figured out
Edited by gbrown65 on 04-05-12 09:07 AM. Reason for edit: No reason given.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
04-05-12 09:59 AM - Post#2211667
you should be able to install a heli coil to restore the thread.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
04-05-12 10:05 AM - Post#2211668
    In response to 62chevy427
There is a balancer installation tool that should be used to draw the balancer onto the crank. You can also heat the balancer in a pot of boiling water to expand it a little and then apply a thin coat of anti-seize to the crank.
Beating it on does the rear main bearing thrust surface no good.
Dan
slammed1
slammed1
Loc: Ark
Reg: 03-28-12
04-05-12 04:37 PM - Post#2211769
    In response to ss3964spd
Hate to hear you had issues with the crank bolt.A trick I have used numerous times when I didnt have an installer was to place the balancer on a cooking rack and heated it in an oven at 225 degrees,while placing ice on the crank snout,when the crank was cool enough and the balancer was hot enough you can use welders gloves or cooking mits and slide the balancer right on with no pounding with a hammer.
Works great in a pinch,just a little extra time involved.
Brian M
gbrown65
Reg: 04-05-12
04-05-12 07:08 PM - Post#2211856
    In response to slammed1
this is a ausome site thanks
nicke
nicke
Loc: Spokane, Washington
Reg: 01-06-12
04-06-12 08:14 AM - Post#2212009
Yep, this is all great advice. I have had great luck with the balancer in a pot of boiling water trick.
Also, its interesting that many of our 327's didn't even have this bolt. Though it is a good idea to use one, they came without from the factory.
-Nick
65' Impala SS- Pics
models916
Loc: Addison, IL
Reg: 05-28-10
04-09-12 06:05 AM - Post#2213022
    In response to nicke
Wheel cylinder hone works just fine on the damper. Doesn't take much, go slow.
Old_Longboarder
Old_Longboarder
04-09-12 02:15 PM - Post#2213177
    In response to models916
The heli-coil repair is the way to go.
"The most precious jewels you'll ever have around your neck are the arms of your children."
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
04-09-12 02:23 PM - Post#2213181
Wouldn't the stones catch on the woodruff key slot?
Dan
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
04-14-12 11:31 AM - Post#2215054
I agree with a few of the suggestions, I put my new balancer in pot of boiling water and let it boil for about 20 minutes to get it real hot.
Then while it was boiling, I had a buddy bring it out of the water when I had the crank snout cooled with a bottle of C02 I sprayed all around the snout and got it cold as ice and brought out the balancer and used a installation too and it slid right on.
I had the same problem with a stripped hole on one. Talked to my machinist and he ordered me a new bolt that had a locking set screw in it. Tap the hole regular size and get one of those locking balancer bolts, tighten it till it is starting to tighten then stop and tighten the set screw in the middle of the bolt. Important thing put some thread locker on the bolt and in the threaded hole before installing it, and never use the balancer bolt to turn the engine.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2005 Yamaha Vstar 1100 midnight custom
Execution time: 0.122 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:13 PM
