Username Post: Anyone have a DTS Customs rear end?        (Topic#282807)
Weccemah
Weccemah
Reg: 03-16-08
06-18-12 08:52 AM - Post#2238674
I bought a DTS customs 12 bolt rear end and I am putting it in the car but the hardware kit that comes with it does not have any shock studs. The original studs on my original rear end do not seem to come off. Anyone else with this rear end, what did you do for your shock studs? Would like some good ideas before I just go ahead and weld something on it. Thanks
1964 Chevy Impala SS
del.impala
Loc: delaware
Reg: 04-13-11
06-18-12 10:05 AM - Post#2238702
    In response to Weccemah
The lower shock stud bolts are probably stuck rusted inside the old bushings. Applying nut blaster or penetrating solution to both ends of the stud shaft. Put the 7 /16th nut back on the bolt and tried to drive it out. Make sure the car is suitably supported and the rear end supported before you do any of this. Good luck!
Execution time: 0.028 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:23 AM
