tarps (7)
Username Post: 61-62 4 speed shifter        (Topic#282442)
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
06-11-12 01:25 PM - Post#2235869
Someone asked and I didn't know the answer so here goes:
In 61-62 was there only one 4 speed shifter for the fullsize cars? No corvettes.
Also was the muncie trans used as well as the Borg T10 4 speed or just the Borg?
If both were used did they use the same shifter?
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
06-11-12 07:36 PM - Post#2236021
    In response to turbo38s10
61/62 cars had borg-warner 4 speeds. don't know about corvettes.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
Verne_Frantz
Verne_Frantz
Loc: hightstown,NJ USA
Reg: 08-22-00
06-11-12 07:45 PM - Post#2236029
For '61 & '62 full size, there was one shifter for the BW T-10. Corvettes also used the T-10 but with a different shifter, but I don't know if '61 & '62 Vette were the same.
The Muncie 4-spd came into production in early '63 production with a different shifter.
Verne
real61SS
Loc: Richmond, Va. USA
Reg: 09-04-02
06-12-12 04:32 AM - Post#2236098
    In response to Verne_Frantz
Verne
Corvette's used the same shifter from '59 to '62
Tommy's Early Muscle Cars
61 Impala SS 409/360 4 speed
61 Ford Starliner 390/401 4 speed
61 Pontiac Ventura 425A 4 speed
62 Corvette 327/300 4 speed
62 Impala SS 409/409 4 speed
63 Ford Galaxie XL 406/4 speed
64 Plymouth 426 Max Wedge 4 speed
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
06-12-12 08:08 AM - Post#2236165
    In response to real61SS
Thanks Everyone thats what I thought.
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
06-12-12 04:40 PM - Post#2236367
I might add that the 61 - 62 passenger shifter body was very much the same as the Vettes except the Vettes had a reverse lock out T handle integrated into the shorter straight shift handle.
Both had the same adjustment procedure which involved using a small block of wood with a notch cut in it to lock the shifter arms in the neutral gate.
Always thought those original small white shifter balls looked like ping-pong balls
Eric
Edited by doubleE on 06-12-12 04:42 PM. Reason for edit: No reason given.
Execution time: 0.039 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:33 PM
