moonsteel
Loc: Ottawa, ON, Canada
Reg: 04-17-12
06-10-12 03:04 PM - Post#2235498
First start today, HP ECU, TPI harness et al.
Car starts and idles, but RPM reads stall!
ECU Not controlling spark.
MSD tach out is wired to IGN "A"
Thoughts?
Danny Cabral
Loc: Ellington, CT
Reg: 11-03-04
06-11-12 12:20 AM - Post#2235654
In response to moonsteel
Need more information:
Which ignition distributor?
Which ignition software setup?
Is it supposed to be controlling timing?
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, A/C, Lentech Strip Terminator AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-over steering, 4" lift, 35" tires |
moonsteel
Reg: 04-17-12
06-11-12 08:37 AM - Post#2235769
In response to Danny Cabral
OEM points style vacuum advance.
Pertronix Ignitor II module.
MSD 6AL.
“CD Box Tach Output or any 12V Square Wave (No Timing Control)”
No.
Only wiring added for ignition is a single wire from the 'tach out' spade on the MSD to the 'A' plug in the IGN.
Danny Cabral
Loc: Ellington, CT
Reg: 11-03-04
06-11-12 01:37 PM - Post#2235872
So you're wired like Figure 8 - page 16 in the wiring manual below?
You're using the yellow/black wire (crank input), and is the Ignitor 2 a magnetic trigger or a ground pulse?
http://www.holley.com/data/TechService/Tech nical/1... (Holley Wiring Manual)
moonsteel
Reg: 04-17-12
06-11-12 01:50 PM - Post#2235878
1) Yellow/Black ('A' on the IGN plug) to MSD 6AL "tach output" spade.
2) Ignitor 2 is a magnetic trigger IIRC.
Danny Cabral
Loc: Ellington, CT
Reg: 11-03-04
06-11-12 02:02 PM - Post#2235883
I believe you have it wired wrong.
The Ignitor 2 red wire connects to keyed/switched 12V.
the Ignitor 2 black wire connects to MSD's white wire.
http://www.pertronix.com/support/tips/default.aspx... (CD box wiring instructions)
http://www.pertronix.com/support/tips/pdf/msd6 seri... (CD box wiring diagram)
The rest of the wiring is Figure 8 - page 16 in the Holley wiring manual:
Lgib
Loc: new mexico
Reg: 01-18-06
06-11-12 04:07 PM - Post#2235930
Is the computer online .I would think it would not start if it was not getting a rpm signal.
69 Camaro 383 sb,GTK650 turbo, Holley EFI HP Stealth Ram, DIS, Holley coils,
60-2 crank trigger, water meth injection, TH350, Gear Venders overdrive |
moonsteel
Reg: 04-17-12
06-12-12 07:34 AM - Post#2236155
In response to Lgib
Do I have to explicitly select online even when the car is being started/running?
moonsteel
Reg: 04-17-12
06-12-12 07:35 AM - Post#2236158
I don't think it's wired incorrectly, I haven't changed anything since I installed it (I've had the Pertronix/MSD for over a year).
It matches this:
The only change this season is the Holley EFI.
(neither the Holley white or yellow loose wires are used)
Edited by moonsteel on 06-12-12 07:38 AM. Reason for edit: added information
Lgib
Loc: new mexico
Reg: 01-18-06
06-12-12 08:40 AM - Post#2236179
No, but if you don't select online and motor is running it will show RPM stall. Do any the sensors show anything on the computer.
moonsteel
Reg: 04-17-12
06-12-12 08:49 AM - Post#2236184
In response to Lgib
Yes.
I followed the quick start guide, all the sensors values made sense when I went through the prestart checks.
When the car was idling, I noticed it said RPM Stall!
Perhaps I didn't select "online". I'll verify.
Danny Cabral
Loc: Ellington, CT
Reg: 11-03-04
06-12-12 09:05 AM - Post#2236188
Wait a second...this whole issue is happening because you're not "online" with the ECU?
Does the Data Monitor display proper sensor values or not?
Does the highlighted cursor float around on the Fuel & Timing Tables (in accordance to MAP & RPM)?
moonsteel
Reg: 04-17-12
06-12-12 10:22 AM - Post#2236206
I'll have to check, I do remember going online, but I have no idea if I did when I started the car for the first time. I just remember seeing RPM stall! but the car was idling.
moonsteel
Reg: 04-17-12
06-16-12 07:46 AM - Post#2237784
Needed to select online, oops.
