tarps (7)
Username Post: EMI?        (Topic#278635)
OLKY55
Gold Supporting Member
OLKY55
Loc: Fulshear, TX
Reg: 09-18-05
03-25-12 02:25 PM - Post#2207334
We have a strange thing going on with the Model A. I killed the engine, and turned off the battery. Then I heard a weird "clicking" sound. It sounds like the IAC, which is mounted under the dash, is cycling. Then I noticed that the power light on the MSD box is also cycling to the same beat. This was happening when the battery was turned off. Note that the HP and the MSD are both hard wired to the battery, before the switch, as required.
I turned the battery back on and started the engine. When I turned it off, everything was OK.
I'm wondering if I have a kind of EMI thing going on? Has anyone else experienced this sort of thing?
http://www.picturetrail.com/olky55
http://scrides.com/Mayhughpg5.htm
1929 Model A Pickup,Fastburn 385,4X2 EFI
1955 BelAir HT,540,Kinsler EFI Stack
1957 Belar 2dr Sedan
2004 Corvette Z06
DeltaT
DeltaT
Loc: San Jose area, CA, USA
Reg: 06-20-02
04-28-12 05:36 PM - Post#2220051
    In response to OLKY55
What do you mean "turned off the battery"?
Also, do you have electric fans?
OLKY55
OLKY55
Loc: Fulshear, TX
Reg: 09-18-05
04-28-12 06:49 PM - Post#2220074
    In response to DeltaT
Battery disconnect switch.
There is an electric fan, but it wasn't running. The truck was in the garage.
2004 Corvette Z06
Danny Cabral
Danny Cabral
Loc: Ellington, CT
Reg: 11-03-04
04-29-12 04:54 AM - Post#2220147
I know your engine isn't "running-on" but maybe it's doing something like this:
http://www.msdignition.com/page.aspx?id=3296
But if the battery was turned off, then it seems like a capacity was discharging through something.
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, A/C, Lentech Strip Terminator AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-over steering, 4" lift, 35" tires
OLKY55
OLKY55
Loc: Fulshear, TX
Reg: 09-18-05
04-29-12 07:02 AM - Post#2220170
    In response to Danny Cabral
I suspect you're right. It seems like a surge or something happens when the disconnect is switched. I've found that the situation will not happen if I wait a while to turn off the battery. Thanks for the replies.
2004 Corvette Z06
Execution time: 0.134 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:45 PM
