GM-Tech
Loc: South Florida
Reg: 06-27-03
11-11-05 03:05 AM - Post#813872
This may be of interest...
GM Fuel System Treatment PLUS, Fuel Sending Unit Corrosion and Fuel System Deposits #05-00-89-078 - (Nov 9, 2005)
2006 and Prior All GM Cars and Trucks
2003-2006 HUMMER H2
2006 HUMMER H3
2006 and Prior Saturn (Canada Only)
2005-2006 Saab 9-7X
GM Fuel System Treatment PLUS GM Fuel System Treatment PLUS, P/N 88861011 (for U.S. ACDelco®, use 88861013) (in Canada, 88861012), is now available.
Added Benefits and Uses The PLUS portion of GM Fuel System Treatment PLUS is the addition of a filmer additive that, when used regularly, can protect fuel system sending units from the corrosive effects of certain sulfur contaminants found in some of today's gasoline.
Sulfur contamination can disrupt electrical continuity of certain fuel sending units and lead to erratic or false fuel gauge readings. With scheduled usage, GM Fuel System Treatment PLUS protects against the effects of harmful sulfurs in gasoline.
You Get Four Benefits One bottle of GM Fuel System Treatment PLUS added to the fuel tank at each oil change:
• Cleans -- Sulfur corrosion from fuel gauge sending units.
• Prevents -- Harmful sulfur components from attacking sensitive fuel system electronics.
• Protects -- By coating metallic surfaces of the fuel system.
• Removes -- Engine deposits left from use of poor quality fuels.
GM Fuel System Treatment PLUS will replace the original GM Fuel System Treatment, P/N 12345104 (in Canada, 89020804). The original formula may still be available for a limited time, and provides the excellent Fuel System Cleaning aspects of the new product without the filmer.
Parts Information Part Number Description 88861011 (for U.S. ACDelco, use 88861013)
(in Canada, 88861012) GM Fuel System Treatment PLUS
CaptainK
Loc: Maryland
Reg: 02-25-02
Re: Fuel gauge problems? 11-11-05 06:48 AM - Post#813873
In response to GM-Tech
Great information, thank you!!
Matt
Loc: SAV
Reg: 09-26-01
Re: Fuel gauge problems? 12-04-05 12:20 PM - Post#813874
jeez, making it more costly per oil change...
racincade
Loc: Iowa
Reg: 05-22-03
Re: Fuel gauge problems? 12-05-05 07:58 AM - Post#813875
In response to Matt
i went and had some orderd for my truck today and its gunna be almost 25 bucks!
2003 3/4 ton HD ext cab 6.0
2004 YFZ 450 - FAST-
Anonymous
Re: Fuel gauge problems? 12-10-05 01:38 PM - Post#813876
It that what is wrong with the gauge on my '00 Silverado??? From a full tank to about 1/2, gauges reads empty, or somewhere in between. Sometimes cornering will make all well for a while. Problem is intermittant, but always with a full tank.
Ryan
Reg: 07-16-03
Re: Fuel gauge problems? 12-10-05 04:14 PM - Post#813877
In response to
Why the heck can't they just make a fuel sending unit that WILL NOT be affected by whatever it is they are affected by!? it says for all 2006 and prior! That tells me that the fuel guage problem I have on my 99 and that many others on here have, newer truck owners will most likely expierence as well! You hear that folks!? GM is now trying to market an additive instead of fixing the problem in the first place! I'm not mad at you GM Tech just mad at GMs quickly deteriorating truck reliability because they want to be cheap and take short cuts and screw the consumers.
Ryan
Reg: 07-16-03
Re: Fuel gauge problems? 12-10-05 04:16 PM - Post#813878
In response to Ryan
Bill, while the truck is in motion, try putting it in neutural and see if that causes the guage to go back up to full instead of bouncing around like it does.
HDANDY
Loc: Nooksack WA
Reg: 03-05-04
Re: Fuel gauge problems? 12-11-05 04:01 AM - Post#813879
In response to Ryan
If I fill up then hit the hiway, it wont come off of full until i turn off the ignition then start it back up drove 200 miles yesterday, stayed on full till i turned off the hiway to get a beer then started it back up and it read 3/4 probably true, why wont it drop while driving
| '07 D/Max Ally Crew Cab White SB
Hijacker 16k usdp
'06 Cougar 314 5er Bunkhouse |
dmljil822
Reg: 09-26-05
Re: Fuel gauge problems? 12-17-05 04:04 AM - Post#813880
Will this resolve an already evident problem or prevent it from occuring? Mine has been faulty for nearly two years and at over $600 to fix, I rely on my odometer to know when to fill up. Thanks
GM-Tech
Loc: South Florida
Reg: 06-27-03
Re: Fuel gauge problems? 12-17-05 04:09 AM - Post#813881
In response to Ryan
Actually, they have improved the fuel level sensors considerably. We don't really see this problem any more. It also helps that fuel quality has improved.
GM-Tech
Loc: South Florida
Reg: 06-27-03
Re: Fuel gauge problems? 12-17-05 04:11 AM - Post#813882
In response to dmljil822
I can't say for sure if it will fix an existing problem, but it says it cleans, so there's a chance it will.
It's not so expensive that it's not worth a try. What have you got to lose.
dmljil822
Reg: 09-26-05
Re: Fuel gauge problems? 12-17-05 04:21 AM - Post#813883
You're right, it would be worth it. Certainly can't hurt. Thanks. Happy Holidays
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
Re: Fuel gauge problems? 12-17-05 04:34 PM - Post#813884
Let us know if it does or doesn't work please!
'09 Silverado 3500HD CC LB D/A LTZ Z71, Mods Annonymous Member #3 |
mr2swpatt69
Loc: VA
Reg: 01-04-06
Re: Fuel gauge problems? 01-04-06 02:40 PM - Post#813885
In response to nodakbassmaster
I have the same problem on my '01. Just bought it. Does anyone know how many miles i can get out of a tank? I have the 5.3.
thanks brian
Ryan
Reg: 07-16-03
Re: Fuel gauge problems? 01-04-06 03:24 PM - Post#813886
In response to mr2swpatt69
Depending on what size tank you have and if it is a 4WD or not.. on my 99 Z71 with the faulty guage and one tire size larger then what comes stock on the trucks, I can get to around 280 miles, used to be able to get over 300 before the light came on, but now I won't go over 280 miles before I fill her up. On my 2001 GMC Sierra with the 4.8L (2WD) with the 34 or 36 gallon tank? I can go 420-450 miles before the light comes on, but the guage has gone out on that as well so I fill her up around 420.
mr2swpatt69
Loc: VA
Reg: 01-04-06
Re: Fuel gauge problems? 01-05-06 05:17 AM - Post#813887
In response to Ryan
Thanks!! I have a 4WD. But I'm not sure what size tank it has, because i have no owners manual.
Ryan
Reg: 07-16-03
Re: Fuel gauge problems? 01-05-06 05:00 PM - Post#813888
how many gallons does it take when you fill her up?
mr2swpatt69
Loc: VA
Reg: 01-04-06
Re: Fuel gauge problems? 01-07-06 03:15 AM - Post#813889
In response to Ryan
i'll let you know this evening. haven't filled up yet.
dmljil822
Reg: 09-26-05
Re: Fuel gauge problems? 01-08-06 07:42 AM - Post#813890
short bed has a 26 gal. tank. long bed has a 34 gal tank regardless of transmission
57tech
Reg: 02-27-05
Re: Fuel gauge problems? 01-12-06 08:44 PM - Post#813891
I have never had that fix any GM I have worked on, great to try it first though. The sending unit in the tank has little tiny fingers that make contact on the resistor card of the sender and these wear-off or get ate by the fuel additives. The repair is to replace the sender which can be bought separate from the pump assembly from GM. Ask me how I know.
silvio
Reg: 02-14-05
Re: Fuel gauge problems? 01-13-06 09:23 AM - Post#813892
I never go pst 350. I stop at 300 to be safe. There have been times at 350 that I could get 24.5 gals inthe tank. Not good if you consider the tank is rated for 25. Rated for 25 does not mean it can not hold more though. They can if you fill very, very slowely and this in turn burps the air out and allows more fluid to enter. Try it and see---but may be bad for the evap system.
silvio
Reg: 02-14-05
Re: Fuel gauge problems? 01-13-06 10:22 AM - Post#813893
In response to silvio
Sorry 26 gallons!!!
Ryan
Reg: 07-16-03
Re: Fuel gauge problems? 01-13-06 05:40 PM - Post#813894
my 99 Z71 shortbed has a 26 gallon tank? I thought it was like 21 or 22
Ryan
Reg: 07-16-03
Re: Fuel gauge problems? 01-13-06 05:40 PM - Post#813895
Ryan
Reg: 07-16-03
Re: Fuel gauge problems? 01-13-06 05:40 PM - Post#813896
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
Re: Fuel gauge problems? 01-13-06 06:02 PM - Post#813897
In response to Ryan
yes
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
Re: Fuel gauge problems? 01-13-06 06:03 PM - Post#813898
In response to Ryan
yes
yes
silveradolsz7153
Loc: Lawrence, KS GO JAYHAWKS
Reg: 11-01-03
Re: Fuel gauge problems? 01-13-06 06:06 PM - Post#813899
Bill
| If you don't like your job, don't go on strike. Just go in every day and do a really half a$$ed job. That's the American way----Homer Simpson |
Ryan
Reg: 07-16-03
Re: Fuel gauge problems? 01-13-06 06:21 PM - Post#813900
In response to silveradolsz7153
If that is really the case, then my gosh I could be getting well over 330 miles to the tank! I really gotta get that fuel guage fixed....
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
Re: Fuel gauge problems? 01-13-06 07:21 PM - Post#813901
In response to Ryan
unless you are really racing from light to light continuously you should have NO problem getting 330 on a tank.
