Username Post: gas sender gasket sealer        (Topic#284143)
Black SD
Loc: TEXAS
Reg: 06-26-05
07-15-12 03:10 PM - Post#2248477
What type of sealer does one use in mounting the gas tank sender unit to the tank.
Does it need to be gasoline resistant?
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
07-15-12 08:05 PM - Post#2248556
    In response to Black SD
use a gasket only. if you use a sealer on a gas tank----well,it should be gas resistant.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
speedygman
speedygman
Loc: Gorgeous Georgia
Reg: 06-27-08
07-15-12 11:11 PM - Post#2248610
Remember the gasket is to be positioned only one position. Make sure it is turned into the position tha ALL holes line up.
Speedygman (Grady)
http://www.picturetrail.com/sfx/album/view/204855 0...
Delray_58
Delray_58
Loc: Scotts Valley, CA
Reg: 03-20-10
07-16-12 06:56 AM - Post#2248676
    In response to speedygman
Mine sealed fine with no sealer, just the gasket on a clean surface.
'58 Delray 283 3-speed
In the family since new
bowtieollie
bowtieollie
Reg: 12-06-99
07-16-12 05:17 PM - Post#2248876
Absolutely no sealer.
Follow Grady's advice and make sure you clock the gasket properly.
Also, the copper washers under the screw heads should be annealed - as the reproductions are "too hard" and do not crush as well as the orignal GM washers were able to do.
Bowtieollie
Chevytalk.com Moderator
Execution time: 0.036 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:27 PM
