1928isgreatnauta (7)
Username Post: carb tag        (Topic#282444)
Bel_AirAmerica
Loc: Evansville,Ind.U.S.A.
Reg: 05-09-02
06-11-12 01:40 PM - Post#2235874
Would anyone be able to post a picture of a carburetor tag.Did all carbs have them?Thanks in advance if anyone has any info.
Rick
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
06-11-12 03:50 PM - Post#2235925
    In response to Bel_AirAmerica
What year? Rochester or Carter? Some are brass, some are aluminum.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
06-11-12 07:37 PM - Post#2236024
quadrajets did not have tags. the #s are in the housing.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
f.i.57chevynut
f.i.57chevynut
Reg: 03-04-09
06-11-12 10:28 PM - Post#2236064
    In response to 62chevy427
Quadrajets are not usually mentioned in stock 55-57 restoration forums.
Bel_AirAmerica
Reg: 05-09-02
06-12-12 10:51 AM - Post#2236218
    In response to f.i.57chevynut
It's a Rochester 1 barrel.
bowtieollie
bowtieollie
Reg: 12-06-99
06-12-12 05:37 PM - Post#2236394
Good point FI!
I would also like to add that the early Qjets did have a foil tag - circular in shape, inserted above the throttle arm.
Bowtieollie
Chevytalk.com Moderator
Bel_AirAmerica
Reg: 05-09-02
06-13-12 06:34 AM - Post#2236542
Sorry,I meant a'55 Rochester 1 barrel
Rick
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
06-15-12 07:18 PM - Post#2237630
You can probably see a variety of tags on E-Bay, if all you want to know is what they look like. There are all kinds of repro and used tags for sale; just type in the kind of carb you're concerned with in the search function. Works for me. Butch/56sedandelivery.
Bel_AirAmerica
Reg: 05-09-02
06-16-12 06:00 AM - Post#2237753
Thanks for the info.
Rick
Execution time: 0.118 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:11 PM
