57Pontiac
Loc: Ste-Sophie, QC, Canada
Reg: 07-09-04
05-11-12 11:08 AM - Post#2224851
Hi folks,
Can you confirm if the front and rear brake drums are the same on a 57?
I have at least 20 drums, how do you tell if they are still good or not?
Thanks!
This
Forum is Sponsored by
WagonMan
Loc: SW Kansas
Reg: 10-26-04
05-11-12 11:14 AM - Post#2224854
In response to 57Pontiac
For a Chevy, yes they are the same after removed from the front hubs.
Visual inspection for heat/stress cracks and measuring of the diameter to make sure they are still within specs.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
53 Chevy 3100 (bought '96)
-250 I6/TH350 |
57Pontiac
Reg: 07-09-04
05-11-12 11:18 AM - Post#2224856
In response to WagonMan
Thanks Charles,
Do you have the specs by any chance?
WagonMan
Loc: SW Kansas
Reg: 10-26-04
05-11-12 11:24 AM - Post#2224857
Shop Manual specifies .060" max oversize, but the max should be cast into the outer edge of the face of the drum.(but this may be a later DOT requirement)
Charles
-250 I6/TH350 |
57Pontiac
Reg: 07-09-04
05-11-12 11:57 AM - Post#2224863
Sorry for my ignorance, but I don't know what .060" max oversize means.
My guess is that I should measure the thickness of the drum "wall", but I have no clue what the thickness should be.
Thanks again
05-11-12 01:53 PM - Post#2224893
You have to measure the inside diameter of the drum. Take them to a auto supply that turns drums and they can measure them. They have a gauge something like this.
57 2dr HT (restoring)
Bruces 57
Reg: 01-03-07
05-11-12 03:50 PM - Post#2224929
In response to acardon
Hello;
Better yet, just buy new drums, they arn't that expensive!
Nothing is too expensive where safety is concearned!
You could sell off your old drum supply to a scrap metal place and get enough $$ for new drums.
Bruce
62chevy427
Loc: laurens sc
Reg: 04-13-06
05-12-12 07:45 AM - Post#2225105
i just looked at some 57 drums and they do not have max size cast into them.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new) |
WagonMan
Loc: SW Kansas
Reg: 10-26-04
05-12-12 09:56 AM - Post#2225155
In response to 62chevy427
That requirement must have started in later years.
Mine are all covered up on the car so didn't look at them, just remembered that some I have worked on were marked.
Charles
-250 I6/TH350 |
This
