Username Post: car stalls when coming to a stop        (Topic#282350)
5chevy3
Loc: Long Beach
Reg: 08-19-11
06-09-12 03:46 PM - Post#2235220
i have a 53 bel air with a 235 engine and powerglide trans. motor has been rebuilt runs great. problem im having is when im driving and coming to a stop the engine stalls out when im on the brakes. car starts right up when im back in park or neutral. if i come to a stop with the car in neutral the engine wont stall. so im assuming i have a transmission problem of some sort. please help me, im getting very pissed off cuz i cant fix it and to cheap to pay.
Edited by 5chevy3 on 06-09-12 03:47 PM. Reason for edit: No reason given.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
06-09-12 03:56 PM - Post#2235224
    In response to 5chevy3
easy don't stop!! no realy sounds like vacume leek
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
06-09-12 04:30 PM - Post#2235232
First of all, welcome. Check the simple things first, what is your idle rpm set at? Could be something as simple at idle adjustment.
Johnnie
Johnnie
John 3:16
2-28s313233
2-28s313233
Loc: DFW Texas
Reg: 02-24-05
06-09-12 05:04 PM - Post#2235242
Make sure your idle is not set to slow. Your car came with a small pot that was mounted on the carb base , that I belive was refered to as a dash pot. there was a bolt on the pot that the throttle rod rested on when you took your foot off the accelerator and slowed the throttle from closing to quickly and stalling the engine. Maybe Gene will see this post and expain it better then I have.
Cleon
1928 Chevy touring
1942 Chevy Sport coupe
1949 Chevy Sport coupe
1954 Chevy Bel Air HTP
1970 El Camino
1971 Monte Carlo
2blu52
Reg: 03-12-02
06-09-12 06:18 PM - Post#2235263
    In response to 2-28s313233
Cleon
well you are right and I can understand it!
THOMAS JEFFERSON
1949er
1949er
Loc: western nc
Reg: 07-14-09
06-09-12 07:44 PM - Post#2235285
I would also say the idle speed needs to be higher....and the float level in the carb may be a little too high....dumping fuel into the engine when you hit the brake...flooding it out but when in neutral....higher revs keeps the engine from dying...
Jimmy in NC
Execution time: 0.034 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:38 PM
