Username Post: oil pressure        (Topic#281587)
mark50chev
mark50chev
Loc: Brandon, Canada
Reg: 09-11-08
05-24-12 08:00 PM - Post#2229472
I just fired up my SBC that I put into my 50. I used the original oil pressure gauge and my SBC pegged out the gauge. I am assuming the original 6 did'nt put out as much pressure?
kensluys
Loc: Bellingham, WA, USA
Reg: 04-18-01
05-24-12 08:07 PM - Post#2229475
    In response to mark50chev
Hi Mark -
The Restoration Guide says the 1950 oil pump was rated at 14psi @ 2000 rpm. Here's the reference:
http://chevy.oldcarmanualproject.com/chevyresto/50...
1951 BelAir - Bought it in 1969, sold it in 1970, found it and bought it again in 1999.
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
05-24-12 08:30 PM - Post#2229492
    In response to kensluys
At cold idle your SBC is probably putting out 20lbs or more. At 2000 rpm it should be up around 30 or 40lbs- at least that's what mine does.
1951 Chevrolet Styleline Special. (350 4 Muncie '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
Execution time: 0.034 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:34 PM
