Is easier to install the pitman arm before you install the steering column in the car or after you install the steering column if you mark it real good where it will be on the steering box?
it is a 54 chevy car.
The shop manual calls for torquing the pitman arm nut to around 100 pounds as I recall. For that reason I installed mine before I put the unti back in the car. I locked the pitman arm in a very good vice to hold it. Other wise you would be torquing against the worm and sector which I felt was probably not a good idea.
THOMAS JEFFERSON
Edited by 2blu52 on 05-08-12 01:59 PM. Reason for edit: No reason given.
