Username Post: Shifter problem?        (Topic#280777)
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-07-12 04:48 AM - Post#2223335
I am rather bummed out got to where I am keeping her started her up not a problem, went to get gas and hose her down before the show and seemed as if everything was fine, I got to a stop sign and put her in neutral, went to put her in first again and nothing? my shifter appeared frozen. I couldn't get her in gear at all so I pushed her to the side and thought the worst, but then (now I will do my best to explain in words) you have the steering wheel in the cab area the three in the tree shifter as well, it then goes through the fire wall, with the steering column, and the shifter follows parallel and comes to a box with rubber bushings on the top and the bottom, looking from the top you also see 2 linkage points on the left side (from the top view under the hood) one for the gears, one for the clutch. they seemed frozen with the shifter, but would move freely if I physically held the flat linkage going through to the tranny moved them by hand. I tinkered a bit and discovered that the bushing that was covering the straight post following my steering column lets say closest to the fire wall was really rough and looked cracked, and on the other side the small box that connected to the linkage and was attached to the steering column appeared to be leaking? after I manually tinkered with the linkage my shifter un froze, and she was shifting again? Because the trip to the car show was a bit far and didn't want to take the chance I went back home. but on the way back home she was shifting fine again? do you or does anyone else know what this box is? Has anyone else ever had this happen with these old 3 on the trees and whether or not it is an easy fix or a pain in the butt? I would not assume its the death because I did drive her home again. any help would be great pics can be shot if it would be helpful. I sent this as a reply message to Johnnie Okie, but wanted to mass post to see if someone else has encountered this, and if anyone can provide me with the repair, and or parts #s I need?
Thank you
-Mark
Edited by inkedflesh on 05-07-12 04:53 AM. Reason for edit: No reason given.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-07-12 05:07 AM - Post#2223339
    In response to inkedflesh
mark.this is so common all part of the 3 on tree join the club!!! worn linkage at colum mabe! linkage sloppy needs bushings at both ends of linkage? so many thing to go wrong.but can be adjusted and fixed most times.but why alot of guys just go to floor shifters http://www.nationalchevyassoc.com/7105_1
Edited by arnieg141 on 05-07-12 05:11 AM. Reason for edit: No reason given.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-07-12 05:13 AM - Post#2223343
    In response to arnieg141
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-07-12 05:27 AM - Post#2223347
to rescue again my friend!! thank you so much, I unfortunately am on a root beer budget presently and was hoping it was a possible fix issue for now? could I buy repair parts for this? or am I going to have to do the floor shifter? I talked with an old timer yesterday, and he said the same thing you just said. I will do that but is there some place to buy rebuild/repair parts for now? plus I gotta say I am a bit attached to my 3 on the tree
2blu52
Reg: 03-12-02
05-07-12 05:33 AM - Post#2223351
Arnies response is correct. Adjust the shift gate per the manual. If the rubber bushings at the shift gate box (upper end of linkage) are worn they need to be replaced, they are Romen Noodle budget cheap. On the lower end of the shift rods at the point they connect to the transmission there should be a small spring and a washer behind the cotter key, this will help maintain tension on the shift linkage and also cuts vibration. Once the linkage is properly adjusted you should have little trouble with it. Us the online manual to obtain the correct information for adjustment.
THOMAS JEFFERSON
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-07-12 05:36 AM - Post#2223354
    In response to 2blu52
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-07-12 08:18 AM - Post#2223406
I want to start off by saying thank you guys a lot for all the help you give us "green horns" of the culture. I pulled up the shop guide and will take a gander at what I got to do, I will definitely work a floor shifter into the budget if it means less stress though. thanks Arnie you know I already respectably call you the man! as well as you my friend 2blu you guys are a wealth of knowledge, and I only hope that the payback I can give you guys is getting my gal running great
Edited by inkedflesh on 05-07-12 08:20 AM. Reason for edit: No reason given.
Dean50
Dean50
Loc: Michigan
Reg: 01-02-07
05-07-12 08:19 AM - Post#2223407
You will learn when not to shift to avoid this problem. If you can't move the stick into 2nd or 3rd to get it loose, it's easy to do under the hood as you hsve found out.
Chevs of the 40s Part Number 365244 shift rod bushings for 49-57. $8.50 a set.
Dean50
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-07-12 08:21 AM - Post#2223408
    In response to Dean50
thanks dean man
Dean50
Dean50
Loc: Michigan
Reg: 01-02-07
05-07-12 08:28 AM - Post#2223411
You are welcome.
It's an easy fix. It might still be a little sloppy but the bushings will help.
I seemed to have the problem mostly when shifting at a real slow speed from 1st to 2nd. Pulling it back down carefully through neutral (so you don't go back into 1st while rolling)would usually free it up without stopping.
You'll figure it out. Have fun!
Dean50
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
05-07-12 08:36 AM - Post#2223413
Mark, these guys are again spot on. I remember driving these cars back in the 60s when I was in high school and experiencing the same thing (out on a date with dirty hands). I wish you had had my Phone number when this happened so I could have told you go on it's the nature of the thing. It is still not as bad as the vacuum shift!
Johnnie
John 3:16
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-07-12 09:44 AM - Post#2223424
thanks mark for the complament. i been working on these cars from abe 8 till today at 63 .but had not realy messed with them from about mid 70's till 5 yrs. ago and joining here and the guys here helped me i forgot alot over the yrs. and still learen more from the guys here.these people on hear are always ready to lend a hand. good luck enjoy it.
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-07-12 11:51 AM - Post#2223449
You know something? now that you say it that way I do recall never having the issues I had yesterday, but did somewhat change up my shift habits yesterday. I typically don't, believe it or not, Shift the way I did I will usually California roll through a stop, but yesterday I put her in neutral! Maybe it was my fault and there's nothing wrong? The bushing near the Control shaft lever, was cracked, not on the linkage. I believe that it may not be a bushing, but almost a dust boot of sorts? the bushings now that I look at the pics on chev of the fortys, was the bushing pieces that connected on the linkage levers not at the top of the control shaft lever. I'm a dumbass it was probably that "way" I should be driving her maybe being a temper mental old coot! a lot of the old timers say, almost like superstition that every old car doesn't drive the same, they have the sweet spots
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-07-12 11:54 AM - Post#2223451
    In response to Cruzin Okie
not a problem Johnnie. I am still new to my gal so I just need to get used to it. I appreciate the regards, and I assure ya ill have more issues coming to the table here at Chevy talk. I have no favorites except this website in my list!!
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
05-07-12 11:59 AM - Post#2223452
The thing to keep mind is we have all been there. Those things happen. Just be sweet to her and all will be good.
Johnnie
John 3:16
2blu52
Reg: 03-12-02
05-07-12 02:00 PM - Post#2223479
I frequently go out and stroke the left front fender of the 2 blu, and sweet talk her. Wife says life would be better if I did the same to her.
THOMAS JEFFERSON
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
05-07-12 02:12 PM - Post#2223484
I love my blue coupe, but I keep thinking about those cold winter nights and I get my priorities straight!
Johnnie
John 3:16
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-07-12 02:33 PM - Post#2223488
Amen to that brother! I get the same I love my wife but she gotta make room for Roberta
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-07-12 03:12 PM - Post#2223495
makeing room for wife!! thats what rumble seats and trunks and pick up beds where made for
Loc: Ellijay, GA
05-07-12 03:12 PM - Post#2223496
No need to lose the 3 in the tree .... get new bushings, readjust linkage with new bushings in place and you should be fine. However, these 3 in the tree cars were never designed for "speed shifting".
FYI, being on a root beer budget is not conducive to restoring one of these babies !
05-07-12 09:16 PM - Post#2223635
    In response to bobg1951chevy
My second wife was named Roberta!!
cederholm
cederholm
Loc: Brooklyn NY
Reg: 09-28-10
05-08-12 07:44 AM - Post#2223735
Of course Bob is right, but that shouldn't prevent you from enjoying your car. It might take a little longer to get showroom perfect, but they are just as much fun to drive in primer as they are in paint!
~ Carl
Carl E. Cederholm
Brooklyn NYC
2-28s313233
2-28s313233
Loc: DFW Texas
Reg: 02-24-05
05-08-12 08:49 AM - Post#2223755
As the others have said, the bushings in the linkage need to be in good shape. You can take the shifter box off the steering coulmn and clean it out and check the spring inside to be sure it is not broken. Sometimes it helps to file the cap on the box to provide a better fit on the shifting shafts, if it is worn excessively. And fill it with a light grease.
Cleon
1928 Chevy touring
1942 Chevy Sport coupe
1949 Chevy Sport coupe
1954 Chevy Bel Air HTP
1970 El Camino
1971 Monte Carlo
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-08-12 11:29 AM - Post#2223807
    In response to 2-28s313233
thank you friend, I appreciate all the advice.
I am Mark By the way
Loc: Ellijay, GA
05-08-12 02:43 PM - Post#2223862
Mark, why not put your name in the signature area .... everyone will know who you are. Works for me.
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-08-12 03:48 PM - Post#2223882
    In response to cederholm
I don't care if I take it to the grave in primer!! shes loud and obnoxious like me!! as long as I got her I don't care if she pisses oil in a parking spot, or if I push her more than drive her I was blessed when I got her, and it makes me happy I agree with him as well, but me and my buddys make alotta stuff work on a root beer budgets especially one hell of a mixed drink with some cheap liquor, or in this case its amazing what kinda stuff you can mod with a torch and a few trips to home depot or a swap meet!!!
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-08-12 04:10 PM - Post#2223885
i agree mark all but the pushing. you can keep these cars going with lock pliers/bailing wire/a philips & regular screw driver gas and oil
Loc: Ellijay, GA
05-08-12 04:16 PM - Post#2223888
Like our choices in women, we all decide what we want from our cars. some like this, while some like that ... and some like it all.
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-08-12 04:21 PM - Post#2223891
Agreed My wife is a hot sparkplug !! She's louder than me but much easier on the eyes.
inkedflesh
inkedflesh
Loc: Nashua, NH
Reg: 04-07-12
05-08-12 04:23 PM - Post#2223893
Yea pushing sucks! but that's why we caravan when we go far places.
Execution time: 0.047 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:37 PM
