DavidDeLuxe
Loc: Grayslake, Illinois
Reg: 09-20-09
05-05-12 05:03 PM - Post#2222882
Hypothetical situation: Let's say that a good friend of mine was rebuilding a 58-62 235 he recently picked up. He is a fairly good guy, but he works in a small home garage and is cramped for space, so he is often tripping over things. In the process of bagging and tagging all the bolts and parts, this very good friend accidentally upset the apple cart that his pushrods were laid on.
Now, this friend thinks that some of them may still be in order. Also, half of the rods have a small round wear mark, while the other half have a slightly bigger round wear mark.
Is there any hope for matching them with their original valves again? Or should he A: Put it back together and hope for the best, or B: now do a FULL rebuild of the engine
R. David Carlson, Jr.
'51 Styleline DeLuxe 2 Door Sedan w. '59 235 & '54 PG trans
'84 Corvette 406ci sbc ACCEL 1000CFM Superram DFI & TH400
This
Forum is Sponsored by
Loc: Ellijay, GA
05-05-12 08:58 PM - Post#2222937
In response to DavidDeLuxe
Being that he is your "friend" I would take the chance and put it back together with what you believe to be correct.
05-05-12 09:03 PM - Post#2222941
In response to bobg1951chevy
I have a friend who did the exact same thing!! What are the odds!!!! In my case... oops... I mean in my friend's case he just gave it his best guess when putting them back in.
arnieg141
Loc: nj
Reg: 10-06-08
05-06-12 05:03 AM - Post#2222990
dave with push rods on a 235 is no real big deal you going to need to adjust all them again any way.you did say you rebuilt motor so a guesse a new cam went in so adjusting would be a defent job being done
| GET ER DONE .. AS I GET OLDER I LIKE FAST CARS I CAN STILL DRIVE. AND VERY SLOW WOMEN I CAN CATCH while still able..arnie garrison |
2blu52
Reg: 03-12-02
05-06-12 06:14 AM - Post#2223015
Nice to have it all in proper order but if it ain't it ain't and all will work out in the long run. I think we all have friends like that. I have one that forgot to put the rotor back in the distributor after installing and setting a new set of points. Ran my brand new battery into the ground.
THOMAS JEFFERSON |
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
05-06-12 06:27 AM - Post#2223022
In response to 2blu52
2blu52, don't you mean your friends battery?
Johnnie
John 3:16
2blu52
Reg: 03-12-02
05-06-12 11:38 AM - Post#2223120
In response to Cruzin Okie
age related spastic brain activity. Of course I meant my friend.
THOMAS JEFFERSON |
05-06-12 12:06 PM - Post#2223130
I once had to... I mean this same friend of mine once had to pull and reinstall the oil pan on his 261 FOUR times due to screwing up the installation procedure! He ran all the auto-parts store out of oil pan gaskets for 15 miles around--true story!!
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
05-06-12 02:50 PM - Post#2223177
Rrausch, I have a friend just like that. He shows up from time to time and does some of the strangest things. I told my wife the other day that he spends 1/2 of his time loosing things and the other 1/2 looking for them. My friend that is.
Johnnie
John 3:16
Vonratnick
Loc: Down Under
Reg: 04-27-06
05-06-12 03:36 PM - Post#2223195
Strewth! You have mates just like me!
What are the chances of that happening
| There's plenty of room for all God's creatures - right next to the mashed potatoes. |
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
05-06-12 06:40 PM - Post#2223246
My friend is named "I don't Know". It seems he showed up one day while my three boys were growing up and has stayed around. Every time something gets jumbled or misplaced or broken....you guessed it "I don't know" did it
Bill Wilson - 51 styleline Deluxe 2 door three speed , fentons and offy 2 carb manifold - is now a 235
Also a 1950 Chevy 2 door styleline deluxe, great patina , no running gear |
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
05-06-12 07:10 PM - Post#2223258
In response to one4dad
Years agfo the mechanics in our dealerdhip never put the push-rods back in the same position and neither did I. Either they are good or bad and the adjustment will take care of the reae. However lifters sold be put back in the same position due to the way they are contacted by the cam lobe.
| ChevGene
1934 Master sedan
1939 Master DeLuxe Town Sedan
1950 Styline DeLuxe Power Glide
1957 Nomad 283 PG
1963 Corvair Convertible |
Ross_S
Loc: Pahrump, NV
Reg: 07-05-02
05-06-12 09:32 PM - Post#2223287
In response to Gene_Schneider
Gene is correct... Just put the pushrods in, adjust them and worry about the IMPORTANT things;, Like who's buying the beer when the job is finished..?..
arnieg141
Loc: nj
Reg: 10-06-08
05-07-12 03:48 AM - Post#2223322
In response to Ross_S
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
05-07-12 05:19 AM - Post#2223345
In response to arnieg141
Also -and this is really important - make sure you install the push-rods in the correct direction! Installing them horizontally will lead to very poor performance.
1951 Chevrolet Styleline Special. (350 4 Muncie '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
DavidDeLuxe
Reg: 09-20-09
05-11-12 07:34 AM - Post#2224786
I'm on the fence right now about how far to go with this new engine.
On one side, I think that work done now is work I don't have to do later, so that's good.
On the other side, I also think that the weather is absolutely beautiful today and who among us wouldn't prefer to be turning the steering wheel outside than be turning the wrench inside ??
DavidDeLuxe
Reg: 09-20-09
05-11-12 07:37 AM - Post#2224789
In response to davidchristopher
Too late - guess I just converted the old Blue Flame into a Porsche flat six
I'm pretty sure this makes me some kind of engineering genius
DavidDeLuxe
Reg: 09-20-09
05-11-12 07:47 AM - Post#2224791
Thank you, Gene. That is primarily what my question was driving at. The manual, rebuild guides, and other sources all stress the importance of returning the rocker/lifter/valve-assem bly to it's original order, and usually the pushrods are included with that.
I lifted the rocker arm assembly off together, so it is only my pushrods that are partially out of order. I haven't gone down to the lifters yet and I'm not sure I will.
This
