Z53Bel
Loc: Austin, Texas
Reg: 07-16-03
04-30-12 10:16 PM - Post#2220958
Hey guys, need an idea here.
I have the front shock I was trying to replace. Simple.. right? Well, first one done. Second one, I had to really do some extra work getting the top nut off but done. Now I have 1 nut on the bottom that is keeping the dang shock in. I have cut through as much of the nut as I can get my dremmel with a cutoff wheel in . I still haven't gotten it off. It's fuzed with the shaft.
Any ideas, tips, what you did, or ideas?
Thanks!
Just starting on my 53 Bel Air restoration, still!
235 3spd 4dr |
This
Forum is Sponsored by
fbama73
Loc: Indianapolis
Reg: 04-17-10
04-30-12 10:49 PM - Post#2220967
In response to Z53Bel
Put a 6 point deep socket on the nut, then put an extension into the socket. Work the extension back and forth- this bends the shock stem just on the other side of the nut. Work it long enough and the stem will break, just on the other side of the nut.
Not much good if you're planning to reinstall the shock, but if you're changing it, it's down, dirty and quick.
05-01-12 04:49 AM - Post#2221019
In response to fbama73
I have cut the stem with a Saws All. Not on 49-54 though.
| Bob Hayden's 54 Chevy, 350 Engine with TH400 Tranny and 94 4X4 Blazer Rear End with 3:23 gears.(FINISHED PICS) </a> My 54 Albums |
jumbojim
"2nd Year" Platinum Supporting Member
Loc: Melbourne, Australia
Reg: 09-25-11
05-01-12 05:51 AM - Post#2221036
If you can get to it, drill through one side of the flat of nut with a 5/16 or 3/8 drill and then turn the nut a half turn and drill it again. You should then be able to break the nut off.
cederholm
Loc: Brooklyn NY
Reg: 09-28-10
05-01-12 06:21 AM - Post#2221044
In response to jumbojim
Choose any method listed above but take your time. When ever I get into a situation like this and go in hot I either make it worse or hurt myself. Personally I would give this job two hours at least and take it slow. Doubt it'll take that long, but if that's the time I have in my head and I take my time it gets done in minutes.
~ Carl
Carl E. Cederholm
Brooklyn NYC
'53 Deluxe MoreDoor, triPPPle Rochesters, Fenton exhaust, dual Porter mufflers, 3" drop, 12v, and Offenhauser shinny bits! |
2blu52
Reg: 03-12-02
05-01-12 08:20 AM - Post#2221085
In response to cederholm
~ Carl
Advise post of the week. Been there done that. At my age I bleed a lot easier and a hell of a lot more than I used to.
THOMAS JEFFERSON |
05-01-12 08:25 AM - Post#2221088
In response to 2blu52
And don't ever work under your car and drop a 10" C-clamp on your teeth... don't ask me how I learned that one!
62chevy427
Loc: laurens sc
Reg: 04-13-06
05-01-12 09:41 AM - Post#2221112
if you do not have to worry about paint or gas leaking,cut the shock with a torch.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new) |
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
05-01-12 09:41 AM - Post#2221113
Oewwwwwww
Christ Robert that sounds like a scene out of one of the saw movies
Jeezze its making my teeth hurt just thinking of it
Every mother on Earth gave birth to a child.Except my mother,she gave birth to a legend .
ALWAYS TRUST PEOPLE WHO LIKE BIG BUTTS,THEY CANNOT LIE. |
2blu52
Reg: 03-12-02
05-01-12 09:57 AM - Post#2221121
You still have teeth?
THOMAS JEFFERSON |
05-01-12 01:54 PM - Post#2221200
One got chipped--it's still chipped, but I considered myself lucky. I was trying to press a new rubber bushing into the end of the rear spring perch. (Note to self: Don't do it that way next time)
This
