Username Post: Aluminum PowerGlide with torque tube?        (Topic#280225)
mahlmann
Loc: Sunnyvale, CA
Reg: 01-20-11
04-25-12 09:12 PM - Post#2219202
A very knowledgeable guy in our local Chevy club who has a lot of automatic tranny experience doesn't like the old cast iron PowerGlides much and recommends going to a more modern aluminum version. My question is, can this be used with a 235 and a torque tube closed drive shaft? Anybody got any experience or advice about this approach? This is going to go into my '50 Tin Woodie, for which I have a '54 PowerGlide and a'53 PowerGlide rear end (3.55:1).
Whaddaya think folks? Thanks for any suggestions and opinions.
Mike Ahlmann
Sunnyvale, CA
Ross_S
Ross_S
Loc: Pahrump, NV
Reg: 07-05-02
04-25-12 09:30 PM - Post#2219204
    In response to mahlmann
The Aluminum powerslide, (pun intended),to my knowledge, didn't come out until the middle of 1962,,, AND it had the same bolt pattern as the V-8's. So you would need some type of adapter to hang it on the back of a 235 I6. Of course converter and starter issues come to mind. Next problem is motor mounts. I'm sure one could fabricate some type of servicable mounts. BUT,, hooking this to a closed torque tube is beyond my expertice.. I'm sure enought money, adapters and work could make a fit...
Now the question, why??? If you want a better trans You can go to an open drive line and use a multitude of later Chevy trans' that would be better and stronger than the powerglide..
Edited by Ross_S on 04-25-12 09:31 PM. Reason for edit: No reason given.
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-25-12 10:29 PM - Post#2219222
    In response to Ross_S
The aluminum Glide first came out in 62 in full size 327 equipped passenger cars; if your 62 had a six (235) or 283, it had a CI Glide. Chevy II/Nova also came with aluminum Glides in 62, as did trucks. All went to the aluminum Glide in 63. No way to connect the aluminum Glide to a torquetube, so it's open driveline conversion time. You're really stuck with a CI Glide if you want an automatic with the 216/235/261, and keep the torquetube. Butch/56sedandelivery.
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
04-26-12 03:30 AM - Post#2219237
Not possible, sorry. The rear housings of the 49-54 powerglides and the aluminum ones are not the same, and to my knowledge, not interchangeable. You would HAVE to swap out to an open driveline as mentioned before...
1951 Chevrolet Styleline Special. (350 4 Muncie '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
04-27-12 04:22 AM - Post#2219599
    In response to davidchristopher
As mentioned above, there was never an alum PG setup for the pre-62 6cyl engines. Thus, no way to mate an alum PG to a torque tube.
Tom Parsons
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
04-27-12 08:19 AM - Post#2219659
The only set up I ever saw that mated a later model tranny (TH 350 in this case) to a torque tube was a disaster waiting to happen. The engine/tranny was pushed too far forward, requiring the radiator to be moved forward as well. The weight distribution was too far forward. Thing handled like a whale wallowing in a turn. With that much work ahead of you I'd strongly suggest either staying with the old tranny or converting to a open drive. There are several ways to keep a original looking engine while gaining a late model tranny and rearend.
Execution time: 0.084 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:17 AM
