Username Post: v8 in a 53 pick up.        (Topic#280022)
sammywells
Reg: 02-10-03
04-21-12 05:31 PM - Post#2217671
Didn't find much in the truck forum so i thought i'd check here. I'v done the v8 swap in a 52 styline but my question is what is involved in doing one in a 1953 3100 truck. Any one done or doing this. I have a 283 and a 3 speed w/overdrive column shift. Just wondering what's involved.
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-21-12 05:43 PM - Post#2217675
    In response to sammywells
I've "heard" the engine needs to be offset slightly to the passenger side in order to clear the steering box. Don't know what exhaust manifolds work though. Clutch linkage would seem to be the biggest hurdle after moving the engine over. Butch/56sedandelivery.
04-22-12 06:39 AM - Post#2217827
I have heard it's a tad easier because of clearance.
gsport
gsport
Loc: Salem, Oregon
Reg: 10-04-09
04-22-12 10:53 AM - Post#2217884
exactly, how much is a "tad"???
Salem, Oregon
1950 chevy, sport coupe. gone, but not forgotten
2011 chevy, SS camaro, synergy green
2011 silverado 4x4 crewcab, 3500 HD
2006 corvette convertible
2014 39ft. 5th wheel
2013 harley fatboy
2006 john deere riding mower
04-22-12 07:40 PM - Post#2218079
    In response to gsport
It's a little less than two shakes of a fat lamb's tail. I did a swap of a Pontiac V8 into my '46 Chevy panel truck many moons ago and i had no problems with the chevy steering or with the exhaust or with the cowl or anything. I just plopped that sucker in and welded some fabricated motormounts in, and started driving it. So I am kinda assuming the panel truck frame and inner fenders and cowl and radiator stayed about the same from '46 to '53. Then too I owned two '54 chevy pickups, both with 235's, and the engine compartments just looked a little wider than the pass cars.
2-28s313233
2-28s313233
Loc: DFW Texas
Reg: 02-24-05
04-23-12 05:14 AM - Post#2218151
Have you checked the Stovebolt Forun? You should find a lot of info there.
Cleon
1928 Chevy touring
1942 Chevy Sport coupe
1949 Chevy Sport coupe
1954 Chevy Bel Air HTP
1970 El Camino
1971 Monte Carlo
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
04-23-12 10:24 AM - Post#2218240
    In response to 2-28s313233
I put a chevy zz4 350 in our 53 chevy pickup with no problems at all. We do have a mustang 11 front suspension though. Set the enging and tranny in on a host and marked where to put the engine mounts. Great fit, steering shaft was put in without much trouble, did have to grind off a slight area on the frame to clear though!
Coach Frank
1975 Corvette, Original owner
1953 Chevy 3100 Pickup
1952 Chevy Styleline Coupe
http://sites.google.com/site/bluejaygarage/
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-23-12 03:56 PM - Post#2218370
I believe a "tad" is equal to three "taints". Butch/56sedandelivery.
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
04-23-12 05:11 PM - Post#2218405
About 70 million miles.
1951 Chevrolet Styleline Special. (350 4 Muncie '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
THE CUT MASTER
THE CUT MASTER
Loc: West Covina CA
Reg: 06-23-09
04-23-12 08:07 PM - Post#2218482
    In response to davidchristopher
NO OFF SET NEEDED, USE 265 CHEVY EXHAUST MANIFOLDS AND SHORT SPARK PLUGS PS I HAVE THE DRIVERS SIDE MANIFOLD EMAIL ME DIRECTLY AT resurrectionvintageautopa rts@hotmail.com
Edited by THE CUT MASTER on 04-23-12 08:08 PM. Reason for edit: No reason given.
Execution time: 0.123 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:36 PM
