Username Post: '55 Instrument Cluster - Help For Speedometer Re-Calibration        (Topic#285197)
lightman45
Loc: Central, NC
Reg: 08-06-12
08-06-12 10:23 AM - Post#2256392
I have a "Custom Rod Gauges" instrument cluster in my '55 Chevy, it was in car when I purchased, so I don't have any instructions. I changed ring gear and pinion and now need to re-calibrate speedometer. Can someone please help me with instructions for re-calibrating this speedometer, or even better if someone could send me a copy of the installation manual with these instructions. I e-mailed the company but no answer. I also called the contact number but got recording that it is no longer a working number. Any help would be greatly appreciated. Thanks, Jim
cnbell
cnbell
Reg: 04-14-04
08-06-12 10:39 AM - Post#2256394
    In response to lightman45
Custom Rod used VDO movements.
Here's a link to their set up.
http://www.egauges.com/pdf/vdo/0-515-012-051 .pdf
Old_Longboarder
Old_Longboarder
08-06-12 10:40 AM - Post#2256396
http://chevelleengineer.home.comcast.net/~chevelle...
"The most precious jewels you'll ever have around your neck are the arms of your children."
john42
Loc: Rockdale Texas
Reg: 12-31-03
08-06-12 10:41 AM - Post#2256397
I had the custom rod gage set in my 57 and have the instructions somewhere. Here is a link to a proceedure for vdo which is the speedometer that is used.
Link: http://www.gomog.com/allmorgan/VDOCALIBRAT ION.html
John King
lightman45
Loc: Central, NC
Reg: 08-06-12
08-06-12 10:52 AM - Post#2256401
    In response to john42
My gauges are a cluster set, so it's not just the speedometer, but also tachometer, and all the other gauges. And, since I have just the one adjustment button, I assume it will be used for adjusting the tachometer also. I'm not sure the instructions for just the VDO speedometer will work with this cluster set. What do you think?
john42
Loc: Rockdale Texas
Reg: 12-31-03
08-06-12 01:28 PM - Post#2256434
I think the one button is multifunction and you push it until you get the cal you wnat. I seem to remember a jumper on the back of the cluster to set the tach cylinders. The next time that I go to my shop, I will look for the proceedure which was for a 57.
John King
Edited by john42 on 08-06-12 01:30 PM. Reason for edit: No reason given.
08-06-12 04:53 PM - Post#2256514
I think the only thing you can adjust/calibrate is the speedo.
You should have gotten the info you needed with the links in the other forum.
Turns out that CRG didn't copy the whole VDO procedure in their intstructions. The VDO procdure should fix everything.
Execution time: 0.044 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:02 AM
