57TOMMY
Loc: Bay Area , Calif
Reg: 08-19-03
08-05-12 07:01 PM - Post#2256177
I have never used the rear support on a starter before but I think they put it there for a reason.
Where do you hook it up on the motor? Use one of the oil pan bolts? I dont see a bolt hole on the engine that would line up like the factory mounts show
Any help would be great , I would love to see pictures
Tommy
Stand up for what is right ,even if you stand alone.
This
Forum is Sponsored by
Zygmo
Loc: Arkansas
Reg: 11-09-09
08-05-12 07:32 PM - Post#2256182
In response to 57TOMMY
There is supposed to be a small hole there for it. Is on all the blocks I worked on, but that only goes up to about the mid 70s for me. I don't know about later blocks.
I normally never used one bacause they can be a bear to put on.
Dean
57 Chevy 4dr Bel Air Wagon My Pix |
08-05-12 07:50 PM - Post#2256188
In response to Zygmo
You should always use one if you run a big original style starter. There's a hole in all the blocks I've ever used, but I haven't used many 86-up blocks with a big starter too.
57TOMMY
Reg: 08-19-03
08-05-12 08:21 PM - Post#2256200
In response to Rick_L
there is a bolt in the side of the block but it is 4 or 5 inches away from the starter. Mine in a 350 / 290 crate motor. I would like to use one but I think i would have to fab something
scloyd
Loc: Mesa, AZ
Reg: 05-11-10
08-05-12 10:10 PM - Post#2256244
An angle iron went up to a 5/16-18 hole just below the head gasket deck. My "small block" has more: bore, stroke, and compression so durn tuttin I use it to hold onto that 502 starter stator with the small block snout on it.
This
