Username Post: DD pac2000 fan controller        (Topic#283175)
Big T
Loc: Simi Valley CA
Reg: 04-14-06
06-25-12 08:28 PM - Post#2241343
For you pac 2000 guys, where along the line did you tap A/C clutch switch? At the pressure switch? (trinary) Which side? At the A/C Blower switch? or somewhere in between?
Thanks in advance.
Tom
Tom
55 4 door BelAir
06-26-12 07:53 AM - Post#2241474
    In response to Big T
I have a Spal controller but it's on the trinary switch. If you don't put it on the trinary, it defeats the purpose of the switch. The trinary lets the fans run only when the condensor pressure requires more air flow, so they will not be running when going down the road unless the engine heat demands it.
57 2dr HT (restoring)
Big T
Loc: Simi Valley CA
Reg: 04-14-06
06-26-12 10:58 AM - Post#2241530
    In response to acardon
Hi Don
Which which of the three leads do I tap into?
Tom
Tom
55 4 door BelAir
06-26-12 11:10 AM - Post#2241535
The trinary switch usually has 2 blue and 2 black wires. The blue wires go to the fan controller and power. The black leads go between the evaporator thermostat switch and the compressor clutch.
Big T
Loc: Simi Valley CA
Reg: 04-14-06
06-26-12 12:40 PM - Post#2241552
Thank you Don
Tom
Tom
55 4 door BelAir
Execution time: 0.133 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:44 AM
