jel1957
Loc: Sugar Land, Texas
Reg: 01-01-04
06-21-12 06:27 PM - Post#2239953
Does anyone have experience with these. I have a Mallory unilite on the car, and the cost of an optic module is $ 90, and you can buy the street fire for $ 120. Thanks for any comments or advice.
This
Forum is Sponsored by
06-21-12 07:39 PM - Post#2239988
In response to jel1957
Not familiar with that one. Do you have a p/n?
MikeB
Loc: Plano, TX
Reg: 08-28-03
06-22-12 01:03 PM - Post#2240217
Installed one on a buddy's car 3-4 years ago and have had zero issues with it. It was introduced by MSD as an "cheap import fighter". However, it was designed in El Paso, TX by MSD, uses some USA-made parts, and comes with MSD tech support.
Unlike the higher priced MSD units, it doesn't have the cool centrifugal advance adjustment capability.
I personally think it will serve you well for many years.
http://www.street-fire.com/distributor.html
Real Hot Rods have a Clutch!
1969 C-10 pickup: 350, TH350
My car pictures
Edited by MikeB on 06-22-12 01:05 PM. Reason for edit: No reason given.
06-22-12 05:02 PM - Post#2240270
In response to MikeB
OK, my narrow mind was thinking of a standard diameter distributor, not a big cap HEI.
jel1957
Reg: 01-01-04
06-23-12 01:02 PM - Post#2240508
In response to Rick_L
One more question. I was going to install it today, but when I look at the wire that comes from the ignition switch - it is mighty small. Does the wiring need to be upgraded, or is the stock wire sufficient? Thanks in advance for the help.
MikeB
Loc: Plano, TX
Reg: 08-28-03
06-23-12 09:29 PM - Post#2240650
I've been running a GM HEI on my 69 pickup for 18 years using a stock ignition switch and the wire that used to run to the ballast resistor. (I removed the ballast resistor, of course.) My GM Chassis Service Manual shows that to be a 20 gauge wire.
I think aftermarket wiring harnesses like AAW and Ron Francis use something around 16 gauge.
My car pictures
Edited by MikeB on 06-23-12 09:29 PM. Reason for edit: No reason given.
06-24-12 06:17 AM - Post#2240697
I think stock HEI installations use a 12 gauge wire to power it.
MikeB
Loc: Plano, TX
Reg: 08-28-03
06-24-12 08:14 AM - Post#2240729
And my truck's wiring still goes through the original, 43 year old firewall connector! Probably something I should replace before giving the truck to my son. Also have to wonder about the ignition switch, but something like an AAW switch requires a different switch connector.
Only electrical problem I've had with it since I bought the truck in 1989 is parking light connectors. Knock on wood.
My car pictures
jel1957
Reg: 01-01-04
06-24-12 05:26 PM - Post#2240908
thanks Mike
This
