Username Post: muncie m20 tranny question        (Topic#282717)
57TOMMY
57TOMMY
Loc: Bay Area , Calif
Reg: 08-19-03
06-16-12 09:04 PM - Post#2238063
I have a friend with a muncie M20 tranny that I am going to buy. What I am looking for are pics of how the shifter comes through the floor. Is it off to the side of the hump? Anybody out there still running a 4 speed ?
Let me know how you like it & what you don't like about it
Tommy
Stand up for what is right ,even if you stand alone.
awsum55
awsum55
Loc: O.P. Kansas
Reg: 09-27-01
06-17-12 12:08 AM - Post#2238115
    In response to 57TOMMY
It's a great transmission, I run one in my '63 Corvette. It has a nice low 1st gear (2.52) and it can handle a modest amount of HP.
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die
6-bangertim
Loc: El Cajon, Calif.
Reg: 11-30-08
06-17-12 12:28 AM - Post#2238117
The HURST tri-five shifter is universal for ALL the 4-speeds - T-10, Muncie and Saginaw. What IS different is the "Installation Kit" with the shift rods and mounting hardware, sold seperately. I'd say that my shifter sits pretty close to center on the hump in my '57, with a Saginaw-3.11.
The Hurst is a PITA to install, as the stick doesn't unbolt from the shifter body. The stick comes forward 2-1/2 - 3" to clear the bench seat, then curves upward and back. I just kinda guessed where I needed to start cutting the floorboard with a tape measure and a paint stick. I never thought until now to make a cardboard template of the shifter AND STICK to make it less of a guesstimate. Once I got the shifter in the car, it was just a matter trimming the hole big enough to clear the stick for reverse and the forward gears.
To do it again, I would make a cardboard cut-out of the shifter and stick - at least you can bend it around under the car! Well worth the effort for the fun of shifting a HURST on a 4-speed!!!
Good Luck, Tim
Too Poor to Restore...My Nifty 150!
Proud owner of MISS NOVEMBER - 2011 Tri-Five Calender
57TOMMY
57TOMMY
Reg: 08-19-03
06-17-12 06:13 AM - Post#2238163
    In response to 6-bangertim
Thanks guys, looking forward to shifting again
Pistol
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
06-17-12 07:09 AM - Post#2238185
I'm not sure which shifter you need to make the stick part removable but here is the stick part
http://www.summitracing.com/parts/HUU-3913780/
Here is my 4-speed setup with the shifter
I modded my floor to have the boot and plate to sit straight, the boot is from a Mazda handbrake
here is the mod area
here is the section I cut out
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
57TOMMY
57TOMMY
Reg: 08-19-03
06-17-12 07:36 AM - Post#2238198
    In response to Pistol
great pics,& thanks for the link to the shifter Thanks Peter. Any concerns or surprises I should look our for? I am going from a 700r4 to the muncie. I know I will have to switch the cross member, Any advise
Thanks all
Tommy
Edited by 57TOMMY on 06-17-12 07:54 AM. Reason for edit: No reason given.
6-bangertim
Reg: 11-30-08
06-17-12 10:16 AM - Post#2238245
What are your gears and tire size Tommy? I was just thinking that a GEAR VENDERS overdrive would be pretty cool on the back of the Muncie!
GOOD pics Pete!
- Tim
Mowman
Reg: 04-13-04
06-17-12 10:36 AM - Post#2238247
Here is what mine looks like.
57TOMMY
57TOMMY
Reg: 08-19-03
06-17-12 12:21 PM - Post#2238290
    In response to Mowman
27 inch tires ,3.08 gears so I dont think my RPM's will be too bad at 65 - 70 mph...around 2500 to 2600 if all of the calculators are correct
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
06-17-12 04:12 PM - Post#2238361
Shifter in 1st gear with seat all the way back.
Mr. Gasket boot with trim ring under carpet.
Shifter works with lots of transmissions. There are two kits for Muncies depending on shift shaft type -- stud & nut, or bolt. Throw away the nylon bushings and use steel bushings.
My floor cutout is around 6"-8" long and 2" wide. The bottom of the shifter will protrude thru the floor in 2nd and 4th gears.
Real Hot Rods have a Clutch!
1969 C-10 pickup: 350, TH350
My car pictures
Edited by MikeB on 06-17-12 04:20 PM. Reason for edit: No reason given.
57TOMMY
57TOMMY
Reg: 08-19-03
06-17-12 05:46 PM - Post#2238414
    In response to MikeB
I like that look thanks Mike
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
06-17-12 05:48 PM - Post#2238416
Good Luck, Tim
My shifter tower is a Hurst, but originally from a MOPAR Pistol Grip in a Challenger. I gave the shift lever to a MOPAR friend, drilled it for the bolt on style holes, as it was a push-in style originally, traded for the right shifter rods and arms, and then bought a Hurst P/N 238-8620 Tri-Five bench seat shift lever. Everything except the new lever were used parts. I can now unbolt the shifter lever from the tower and pull the trans with the shifter tower/linkage intact. All I really have in the setup is what the new shifter lever cost ($$$). I just could'nt see having to remove the shifter tower to remove the trans. Butch/56sedandelivery.
busyguy8
busyguy8
Loc: SF Bay Area, CA
Reg: 11-21-04
06-17-12 11:08 PM - Post#2238556
so ya really gonna do it, Tommy?
Aquired a '56 2dr hdtp BelAir on 6/9/05!
Link to my pics!
-bill
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
06-18-12 03:52 AM - Post#2238570
  • 56sedandelivery Said:
My shifter tower is a Hurst, but originally from a MOPAR Pistol Grip in a Challenger. I gave the shift lever to a MOPAR friend, drilled it for the bolt on style holes, as it was a push-in style originally, traded for the right shifter rods and arms, and then bought a Hurst P/N 238-8620 Tri-Five bench seat shift lever. Everything except the new lever were used parts. I can now unbolt the shifter lever from the tower and pull the trans with the shifter tower/linkage intact. I just could'nt see having to remove the shifter tower to remove the trans. Butch/56sedandelivery.
I'm pretty sure the 55-57 kit had had a bolt-on bench seat shifter handle back in the 60s-70s. It was much easier to install than the new welded-together setup.
Butch, will you post pictures of yours? I'd like to see how the shifter handle connects to the shifter mechanism.
My car pictures
Edited by MikeB on 06-18-12 03:58 AM. Reason for edit: No reason given.
Pistol
Pistol
Reg: 11-11-02
06-18-12 04:39 AM - Post#2238578
Butch is the shifter you have a 3916790 http://www.hurst-shifters.com/?wpsc-product=compet...
Pete
57TOMMY
57TOMMY
Reg: 08-19-03
06-18-12 06:37 AM - Post#2238617
Thanks guys . Yep B Monte called Saturday, he has the M20 out of his Z. I told him after Hot August Nights I will call him.
Tommy
tri5ss
tri5ss
Loc: Massachusetts
Reg: 12-14-00
06-18-12 11:09 AM - Post#2238726
Thanks all
Tommy
The 700R4 is longer than the Muncie so you will need a new driveshaft. I don't remember the exact dimensions for the Muncie but the 700R4 is 30.75in and I believe the Muncie is about 3 inches shorter.
From the Hemmings website:
"On GM Turbo 350, 200-4R and the 700-R4 automatics, the transmission mount is the same as the one used for the Muncie."
If the input shaft has 10 splines, then the output shaft should be 27, same as your 700R4.
Good luck with the install. I took a Muncie out and put in a 200 4R and really miss the Muncie.
Randy
Tri5SS
'55 210, GMPP ZZZ, 200 4R, 12 bolt 3.73 posi, CPP P/S, ABS D/B.
http://www.picturetrail.com/tri5ss
Nothing is foolproof to a sufficently talented fool!
57TOMMY
57TOMMY
Reg: 08-19-03
06-18-12 12:32 PM - Post#2238774
    In response to tri5ss
Thanks Randy ,yep ready to shift again
cnbell
cnbell
Reg: 04-14-04
06-18-12 01:05 PM - Post#2238788
Tommy, don't you have a 700r4 in it ?
57TOMMY
57TOMMY
Reg: 08-19-03
06-18-12 06:59 PM - Post#2238923
    In response to cnbell
yep, 700r4 bowtie setup, works fine I just want a change.
By the way Craig, how have you been? Is that a Nomad I see you working on
Edited by 57TOMMY on 06-18-12 07:00 PM. Reason for edit: No reason given.
busyguy8
busyguy8
Reg: 11-21-04
06-18-12 08:55 PM - Post#2238957
Tommy,
Monte called me and got your number about the tranny. I'm excited you're goin for it!
-b
Link to my pics!
-bill
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
06-18-12 10:53 PM - Post#2238974
My digital camera is currently "T/U"; it's got 2 large dots in the viewer. I had to drill 2 holes for the bolt-on stick, as the shifter tower was originally a push-in stick with the MOPAR pistol grip. I also had to use a press to "squash" the reciever in a little and use spacers; it's tight/solid. Butch/56sedandelivery.
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
06-18-12 11:00 PM - Post#2238976
My shifter tower is an original factory equipment MOPAR/Hurst Pistol Grip that I gave the shift lever away on, drilled some holes, and bought the bench seat style tri-five shifter lever. The only number on the tower, other than the 3 patent numbers, is 6356. I've not actually seen a bench seat style shifter lever for a tri-five that was'nt a welded on stick; and was surprised to see they even made a bolt-on stick; bought it off E-Bay new. The reverse lever is longer and somewhat curved, but the reverse rod I used had enough threads to adjust it correctly on the MOPAR/Hurst. Butch/56sedandelivery.
57TOMMY
57TOMMY
Reg: 08-19-03
06-19-12 06:01 AM - Post#2239046
Hey Busy
I am glad you are excited I just hope you stay that way when I ask you to come over & help me
Tommy
2Loose
"9th Year" Platinum Supporting Member
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
06-19-12 11:14 AM - Post#2239141
Don't know if this will help ya much or not, but here it is:
I had an M20 I was going to use in the '55 gasser project, but then I ran across an early Doug Nash 5 speed in good condition, the Hurst shifter lever for that had to be cut just above the bolt holes and rewelded in a more forward leaning position to clear the bench seat. But it is positioned easily at hand for shifting, it's a comfortable position. The position of the shifter mechanism under the floor tunnel looks to me to be very close to if not exactly the same as the Hurst for the M20 would have been. I gave my M20 to a buddy who is building up a nice cruiser homebuilt 2,000 lb roadster with a mild 283, the M20 will be perfect for him. FWIW, here's a pix of how the shifter fit came out in my '55 with the Doug Nash and the bench seat:
The cardboard template is for the vinyl boot I sewed up for it. Here's how it looks with the boot installed before I put the seat back in:
The cord running up the tunnel from the shifter is for the line lock button mounted just below the shifter knob. It is amazing how many times I use that button to hold the car at a stop sign or a stop light when it wants to roll forward or backward while putting it in gear to get going. Way easier than working with the parking brake!
Good luck with yours, show us some pix as it goes in.
Aloha,
Willy
awsum55
awsum55
Loc: O.P. Kansas
Reg: 09-27-01
06-19-12 03:05 PM - Post#2239201
    In response to 2Loose
That statement would make people that don't know your history believe you don't know how to drive a stick.
REBORN55
REBORN55
Loc: DeSoto, Illinois. 62924
Reg: 01-21-01
06-19-12 05:17 PM - Post#2239251
    In response to awsum55
This what mine looks like with the late model M-20
Ken http://www.picturetrail.com/reborn55
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
06-19-12 05:36 PM - Post#2239258
    In response to REBORN55
Ken,
Nice looking interior. You don't see many that color . Same goes for the paint.
My car pictures
cnbell
cnbell
Reg: 04-14-04
06-19-12 06:05 PM - Post#2239265
Hi Tommy,
Yeah, bought the Nomad around Thanksgiving, needs a full resto. Not sure of the direction yet, hopefully I'll figure that out as I go....
busyguy8
busyguy8
Reg: 11-21-04
06-19-12 07:11 PM - Post#2239287
anytime Tommy!
Link to my pics!
-bill
Execution time: 0.059 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:08 AM
