St Joe 1956
Reg: 02-24-12
02-24-12 09:20 PM - Post#2194899
It was suggested that I post on here also, I've posted on the Nomad site. I have a '56 Nomad, I'm doing a frame off and have broken several bolts on the hinges and tailgate strikes.Is there a good access to repair or replace the blind plates the bolts went into? Thanks
This
Forum is Sponsored by
WagonCrazy
"7th Year" Platinum Supporting Member
Reg: 06-07-05
02-24-12 09:25 PM - Post#2194901
In response to St Joe 1956
I just finished drilling and removing my old rusted tailgate hinge bolts today, Used an ezout after drilling all the way thru the center of each bolt. They came right out with a little elbow grease.
The plates on mine look ok and are loose, but i havent tried to remove them yet. They do need to be sandblasted and primered before they go backin. to keep the rust factor minimized.
I may even junk 'em and go to a modified hinge that is hidden inside the bottom of the tailgate. I'm sure someone sells something CNC'd for that by now...
57 Nomad C4-LS1 Pics
57 210 9passenger wagon Pics |
St Joe 1956
Reg: 02-24-12
02-24-12 09:30 PM - Post#2194906
In response to WagonCrazy
Thanks, I was just looking at you LS1 photos. I'm doing a Nerd Rod frame and LS1 with 4L60E. Got a long way to go but no hurry. I've had mine since 1967. This should be the last time I build it....
rj_ly
"6th Year" Gold Supporting Member & Tri-5 Calendar Creator
Loc: Southwestern OH
Reg: 11-15-02
02-25-12 09:45 AM - Post#2195007
I just saw someone doing this repair on a '55/6/7 Nomad or Wagon.
They said to cut a window in the metal under the hinges (underside of the body) so the nut plates could be accessed.
I know I had a screw for the striker plate on my (windowed) Sedan Delivery break off in 1982. I had to drill and tap the hole to the next larger size bolt. Luckily the striker plate went back on with no modifying.
57 Hrdtp(mine for 40 YEARS JULY 12)
57 210 4-dr Sdn(37 yrs Aug 12)
57 Hrdtp(32 yrs Jan 12)
57(windowed)S. Delivery(31 yrs Oct 12)
57 150 Wgn(24 yrs Mar 12)
57 210 2-dr Sdn(8 yrs Oct 12) |
St Joe 1956
Reg: 02-24-12
02-25-12 01:14 PM - Post#2195067
In response to rj_ly
Thanks, that what I have in mind. I didn't know if I was the only one to have this problem. I'm planning on cutting slots to get the blind plates out, then repair the slots after...
02-25-12 08:12 PM - Post#2195245
If it is possible, it would be best to weld a bolt to the broken screws. Then you can just use a wrench or rachet to remove the broken screws. There needs to be enough of the screw still there to weld to it without welding to the plate. The heat from the welding will help with breaking it loose as well. You can also spray some Kroil or SeaFoam penetrating oil in there to help as well. I've used that method on broken and frozen bolts and screws a lot and it has always worked.
1957 Nomad sport wagon |
St Joe 1956
Reg: 02-24-12
02-26-12 06:34 AM - Post#2195331
In response to wagonman100
Thanks for the ideas. I used PB Blaster, heat and all the regular methods til the rounded out or broke off. Now I'm going to drill, EZ out or retap if necessary. I have one of the plate for driver side strike that has fallen down into the cavity after I got the bolts out. I'll have to retrieve it in some manner. I'm planning on cutting a slot somewhere to gain access then repairing the slot. Thanks again for the input.
C57Heaven
Loc: Ohio USA
Reg: 08-02-00
02-26-12 01:06 PM - Post#2195482
have you guys seen this?
Anybody used it?
http://www.loctitefreezeandrelease.com/
Peace,
John H.
55 BA 2dr Sed owned since 1979, sold 6/1/09;
1957 Conv (starting to restore) |
St Joe 1956
Reg: 02-24-12
02-26-12 07:58 PM - Post#2195667
In response to C57Heaven
I've never seen this before, but I have seen guys use dry ice
St Joe 1956
Reg: 02-24-12
02-26-12 07:59 PM - Post#2195668
I'm gonna try to locate this and see how it works
C57Heaven
Loc: Ohio USA
Reg: 08-02-00
02-27-12 06:20 PM - Post#2196038
800.624.7767 Loctite.
Peace,
John H.
St Joe 1956
Reg: 02-24-12
02-27-12 07:55 PM - Post#2196081
Thanks, I see you had your car for 30 years, I've had me "56 nimad since June 1967. I'm the second owner. Bought it when I was 16,from a company that bought it new for a salesman car. I gave $100 for it and drove it after I put a battery in it.
57belairman
Loc: Missouri City Texas USA
Reg: 03-16-02
02-27-12 10:43 PM - Post#2196150
I saw it at Fastenal today. Be careful -45 degrees. It will quick freeze anything in it's path.
Life is short, Eat dessert first, I always do!!
Picturetrail
57 2dr ht red
57 Convertible
57 Nomad
57 2dr Sedan
57 3100 Pickup
55 2dr Sedan
56 Suburban |
St Joe 1956
Reg: 02-24-12
02-28-12 08:14 PM - Post#2196483
In response to 57belairman
Thanks, we have a Fasten-All close by
This
