Username Post: Anyone know where I can find a pinion yoke/washer?        (Topic#269859)
09-28-11 09:29 PM - Post#2141996
I'm piecing a rear together and I need to round up a pinion yoke and the thick washer that goes under the pinion nut. There should be bunches of them around, but I can't locate any.
Tom Parsons
rj_ly
"6th Year" Gold Supporting Member & Tri-5 Calendar Creator
rj_ly
Loc: Southwestern OH
Reg: 11-15-02
09-29-11 09:04 AM - Post#2142157
A drive line shop? Like one that cuts axils, driveshafts, and such.
57 Hrdtp(mine for 40 YEARS JULY 12)
57 210 4-dr Sdn(37 yrs Aug 12)
57 Hrdtp(32 yrs Jan 12)
57(windowed)S. Delivery(31 yrs Oct 12)
57 150 Wgn(24 yrs Mar 12)
57 210 2-dr Sdn(8 yrs Oct 12)
Old_Longboarder
Old_Longboarder
09-29-11 10:08 AM - Post#2142176
    In response to rj_ly
I bought three center sections at the swap meet a few years back just to have in stock, one of them was partially disassembled, but pretty sure I have what you're looking for.
"The most precious jewels you'll ever have around your neck are the arms of your children."
Old_Longboarder
Old_Longboarder
09-29-11 10:20 AM - Post#2142181
I've got the yoke and washer, it's from one of the later years, I'll E mail you a couple of pictures cause I don't know how to post them here.
It has one funny looking spot on it, don't know how that happened, casting flaw maybe??
Old_Longboarder
Old_Longboarder
09-29-11 10:25 AM - Post#2142183
Email just sent with two pictures.
09-29-11 07:15 PM - Post#2142402
Got it. Great. THANKS!
Tom Parsons
09-30-11 07:01 AM - Post#2142532
Well, now I just need to locate a good ring and pinion set, either 3.08 or 3.55. The set I have is junk!!!!!!!!!!!!!!!
Tom Parsons
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
09-30-11 08:37 AM - Post#2142560
I have a couple for 10-bolts laying around. Let me know what OD and ID you need.
You might also try these guys: http://www.dallasdifferential.com/
I bought a bunch of 10-bolt parts from them last week.
Real Hot Rods have a Clutch!
1969 C-10 pickup: 350, TH350
My car pictures
09-30-11 02:44 PM - Post#2142626
    In response to MikeB
It is MANDATORY that they be from a 57-64 Chevy rear!!! The later 10bolt gears WILL NOT interchange with the 64-earlier rears.
Tom Parsons
Old_Longboarder
Old_Longboarder
09-30-11 02:49 PM - Post#2142627
Tom, The parts differential I have has a set of 343 gears set in it, as I remember. They appear to be in good shape, couldn't check a gear lash pattern, because of it being partially diasassembled upon purchase. It appears someone had taken the yoke off to replace a pinion seal, so no pinion preload to do any checking.
I'll get out behind the garage this weekend and check it out further and get back to you, if that ratio will work for you. I could ship those and the yoke and washer at the same time.
09-30-11 06:23 PM - Post#2142663
OK, let me know.
BUT, if it is a Chevy rear, the ratio will be something different from 3.43, such as 3.36 or 3.55.
Tom Parsons
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
09-30-11 06:58 PM - Post#2142678
Tom, I meant the pinion nut washer, not the gears!
My car pictures
Old_Longboarder
Old_Longboarder
10-01-11 09:03 AM - Post#2142793
  • DZAUTO Said:
OK, let me know.
I don't remember so well anymore, yeah, they're 336s.
Belair56OKC
Loc: Edmond, OK
Reg: 09-28-11
07-02-12 02:13 PM - Post#2243681
Tom, I am currently looking for recommendations on a streetable rear end for a 56 Chevy SBC 350/325 HP, Turbo tranny. The original is leaking and clunky when shifting . I was given your name by a fellow forum gear head that said you knows the Tri-Fives inside and out! Live up the road from you in NW OKC. Thanks
Russ
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
07-02-12 06:03 PM - Post#2243764
    In response to Belair56OKC
Russ, if you don't hear from Tom here, start a private topic with him. He is definitely the right guy.
My car pictures
Belair56OKC
Loc: Edmond, OK
Reg: 09-28-11
07-02-12 07:35 PM - Post#2243792
Thanks Mike B...Enjoy the holiday..
Execution time: 0.039 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:57 PM
