OldJules
Reg: 05-27-10
04-12-12 08:12 AM - Post#2214263
I see that using an S10 chassis under an early Chevy is a good way to go. I'm just wondering where I can find some good information concerning this mod.
Thank You
04-15-12 08:10 PM - Post#2215555
In response to OldJules
Where did you see that? I know a company that makes a bracket kit to use a 49-54 pickup body on a S10 frame.
1996 Chevy Monte Carlo
2002 Dodge Dakota Quad Cab
2013 F150 Crew Cab |
gmsnowball
Reg: 10-23-11
05-06-12 06:28 PM - Post#2223241
I know a few folks that use S10 rear ends and transmissions but not the entire frame.
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
05-08-12 07:39 PM - Post#2223989
In response to gmsnowball
Are you sure they wern't talking about the pickups? There is a company making a simple conversion kit for that, but I'm not so sure about the cars.
05-15-12 09:33 PM - Post#2226382
These are pickups
http://ad-engineering.com/
http://www.e-zchassisswaps.com/ These guys have 41-59 kits
05-15-12 09:40 PM - Post#2226384
Just read a story on a guy that put a 41 F**d two door sedan on a S-10 frame.
The magazine is Rod Action Sept 1991.
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
05-16-12 05:17 AM - Post#2226439
I've seen lots of rods on S-10 frames. Some work better than others. Their wheelbase lends them to rod applications, however, some rods are narrower in the front end than that frame will accommodate. The trucks don't "pinch" in the front as bad as the cars do in most cases. Check it out with your tape measure to see.
