Username Post: Adding dual exhaust 64 belair
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
01-02-18 07:51 PM - Post#2719829
    In response to Sweed62
Attachment: DSCN0140.JPG (158.82 KB) 8 View(s)
Sveene,
The holes were horizontal for the exhaust mount to the rear of the tire, like the ones in your picture. The front hole is for a mounting tab on the exhaust bracket (to keep it from turning) and the rear hole is for the hex bolt.
See my picture -you can see the tab if you look closely you can see the tab in the frame hole.
I see the 2 vertical holes in your frame for the hex mounting bolts (in the picture ending in 137) behind the tire.
here is the bracket in my picture with this post. Note the tab and one mounting hole.
https://www.show-cars.com/cgi-bin/commerce.cgi?pre...
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
Execution time: 0.58 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:44 PM
