Username Post: Timing issues
IgnitionMan
Reg: 04-15-05
01-02-18 07:35 AM - Post#2719765
    In response to malibu27
No, actually, he probably helped the no fresh air into the PCV system without knowing why.
I'd redesign the system, work it out right, it does help the engine when done properly.
Nope on that valve, it only has a small proximity from one side of itself, to the other, needs suction on one side of the engine, fresh, clean ambient air inlet on the other side, full across the engine air path.
I didn't look, how much is that con job of a "valve"? Gotta be outrageous.
Execution time: 0.188 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:33 AM
