Username Post: Wont start
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-01-18 12:50 PM - Post#2719687
    In response to Jeffrey0180
Yep. Use a ratchet or breaker bar. The starter will go way too fast. You may need someone to put their finger over the hole and watch the mark. The easiest way I have found to get a ratchet on the crank is take the skid plate off, lay on the ground, and go up through from the bottom. I think a small block is a 5/8 socket and big block is 3/4. Make sure you can read the numbers on the pointer. 0 isn't exactly in the middle.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
Execution time: 0.2 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:44 AM
