Username Post: Wont start
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-01-18 07:40 AM - Post#2719637
    In response to Jeffrey0180
If this is a 96 or newer, disregard what I'm about to say. You need a scan tool.
Are you sure you were on TDC compression stroke? If the rotor is under the terminal with the wire going to #1 cylinder, it should start. If it's under #6 you're 180° out. Check the firing order. 1-8-4-3-6-5-7-2.
Jeff
Execution time: 0.229 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:20 AM
