Username Post: Electric Cutoff Switch
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-01-18 05:13 AM - Post#2719622
    In response to 50sChevys
Hi 50, Good Idea, I have one between the front bucket seats of my Tudor. Its just a plastic key race type and I think its just mechanical and isn't any kind of relay or solenoid.
It's an easy fit in this as the battery is under the passenger seat and its right beside it.
I don't use it very often as I have the electric water pump which runs for 2 minutes after shut down at the key. Plus if you flick it off with the engine running you can destroy the alternator controls. But when battery charging or for security its a gem.
Cheers kiwi
Edited by Bel Air kiwi on 01-01-18 05:14 AM. Reason for edit: No reason given.
Execution time: 0.181 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:26 AM
