Username Post: Adding dual exhaust 64 belair
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
12-31-17 09:49 PM - Post#2719609
    In response to shaunv8
The drivers side will match the passenger side.
The passenger side brackets will face the frame in the opposite direction.
The drivers side bracket directly behind the muffler could be welded to the frame (the passenger side will have two vertical holes in the frame for the bracket that has two holes in it for the hex head mounting bolts).
The other two brackets on the drivers side -the mount behind the tire uses 2 hex bolts to mount the bracket. The drivers side bracket (if its an orginal bracket) just behind the tire has one hex head bolt to mount the bracket.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
Execution time: 0.185 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:29 AM
