Username Post: Adding dual exhaust 64 belair
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
12-31-17 07:05 PM - Post#2719590
    In response to shaunv8
The exhaust is never mounted to the body.
Factory exhaust is mounted to the frame using exhaust system mounts that bolt to factory holes already drilled in the frame.
I have pictures of all the factory mounts that are bolted to the frameon the drivers and passenger sides,that I can post when I get home later tomorrow.
These factory exhaust mounts are sold reproduction as a set or indiviually. The factory bolts are self tapping fine thread hex head bolts, also sold reproduction. All the mounts are bolted to two factory holes in the frame for each mount. There are 3 mounts per side.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
Execution time: 0.255 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:10 PM
