Username Post: what type fan blade for 305 chevy
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
12-06-17 06:08 PM - Post#2717118
Hi DZ, I would agree that old system works fine, and if it needs a bit of help then the simple drum type early impala shroud will help.
Electric fans only come to the fore when you haven't got room or you want some economy
My F250 has a huge eight blade steel fan and an enormous radiator with no shroud. It doesn't get hot even parading as it was made with a Granny low gear so you can idle around the farm feeding out.
The downside of that is that big fan out on the motorway at a couple of thousand revs is probably sucking 15Hp or more for nothing as the airflow makes it redundant. With a fixed fan you have to set it for worst case scenario and waste the energy the rest of the time.
However, given how big the fan is it's pretty bullet proof and simple. Short of throwing a belt or getting a leak you will never have to worry about it. Being a 3/4 ton it was configured for towing and slide on campers etc so it's not really over kill if you really load it up.
Cheers Kiwi
Execution time: 0.531 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:44 AM
