Username Post: Heater Plumbing
11-28-17 02:33 PM - Post#2716122
    In response to Jack Crain
If you have a 235, the hose connection at the thermostat housing is the "hot" line and the one at the water pump is the "cold" line.
Normally, you want the flow through the heater core to be from bottom to top. This reduces the chance of an air bubble getting trapped in the core. Therefore, the thermostat housing hose should connect to the lower nipple on the core and the water pump hose should connect to the upper nipple.
If any questions, please ask.
Execution time: 0.27 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:23 AM
