Username Post: HWY-22 kit - adapt to '59 Bel Air?
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
11-15-15 09:08 PM - Post#2589162
    In response to Hobart
  • Hobart Said:
Hi Donny,
Years ago I bought a Highway 22 kit #500695, with the necessary add-ons to use in my '58 Delray. I never used it, and now I'm considering using it in my '59 Bel Air. Are you able to tell me the additional part numbers I would need to do this?
Also, after all these years the instructions for the kit are lost, is it possible you could mail me another set?
Thanks Donny!
They are available right on line. If all the bags are opened, you're gonna have a hard time identifying what is what I'd think. As far as what all else you'll need, there is a ton. The cluster alone will drive you nuts as there are 3 connections at several locations on the Classic Update version. The T/L pigtails are available, but not with the proper colored wires. The ignition switch will not mount in the dash properly, the P/L connections are an issue, there are no H/L bucket harnesses in the HWY 22. You'll need to buy them separately. By the time you buy everything that you'll need, might be better off getting the Classic Update kit. I'll be happy to check everything for you if want, let me know.
Execution time: 0.526 seconds.   Total Queries: 9   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:12 AM
